"DIY MODS" and TRICKS to SAVE $$$$$$
#1342
#1343
FWIW, the rubber antenna's from Advance have a hard plastic base that is brittle, and they break every other month or so.
keep your receipt & package handy, and just keep swapping them out. they have like a 90 day warranty, and they always break prior...but you can't always find the receipt
#1345
Have you guys seen this yet for antenna on Street Glide?
Antenna Eliminator kit on Harley Davidson Street G - YouTube
Worked for me.
Worked for me.
I don't think the cable and connecter is just going to hang there..scary as hell if that gets wrap up in the wheel or belt! I guess you would just zip tie it up or better yet cable clamp it out of the way?.
#1346
I saw that the other day and was actually thinking of doing that on the Ultra Limited..
#1348
Worked for me.
Worked for me.
2 Zip ties did the trick. You definitely lose some signal strength at times but I would bet its comparable to the other antenna solutions which all lose strength. For me, it was perfect. I rarely use the radio anyways, but its there if I need it and it was the cost of 2 zip ties.
#1349
