battery tender
ORIGINAL: jcd_27265
well I would bet this has been talked about before but I am looking for info on the best tender available for both my SG and my Big Dog any help would be greatly appreciated.
John
John
Battery Tender Plus 12 Volt 1.25 Amp Battery Charger
![](http://www.batterymart.com/images/products/full/del-021-0128.jpg)
Your Price: $45.95
Quantity Price Each 5-59$41.95 60+$37.00 Quantity:
Product Description: The Deltran Battery Tender Plus is a 1.25 amp battery charger designed to fully charge a battery and maintain it at proper storage voltage without the damaging effects caused by trickle chargers. Included is a quick connect harness for hard to reach areas.[ul][*]Includes one Clamp Harness and one Lug Harness[*]Optional cigarette plug allows you to charge & maintain your battery directly from your vehicle's lighter socket (only use if socket energized with key off)[*]Temperature compensated to ensure optimum charge voltage according to ambient temperature.[*]Automatically switches from full charge to float charging mode.[*]Reverse Polarity Protection to ensure user safety.[*]Complete 4-step charging program (Qualification, Bulk Charge, Absorption Mode, Float Mode).[*]BTP microchip technology virtually eliminates battery destroying sulfation[*]Built in 72 hour safety timer protects marginal batteries from over charging[*]Charge/Maintain up to 4 batteries (of similar type - in parrallel)[*]Spark Proof[*]Size: 4.88 x 3.25 x 2.88"[*]Input Power: 115VAC @ 60Hz[*]Temperature Range: -20F to 120F[*]UL, ETL, CSA listed[*]10 year Warranty![/ul]Battery Tender Plus's new BTP microchip technology applies the correct peak charge, then automatically maintains the battery at the perfect float voltage which virtually eliminates battery destroying sulfation. What does all this technology mean for you? A battery that is ready to go when you are! BTP microchip technology will extend the life of your battery.The new Battery Tender Plus will correctly charge and maintain any type of lead acid battery - AGM (absorbed glass mat) or sealed calcium batteries.
Deltran Battery Tender Plus. This is the best price I found on Ebay ($43 with free shipping): http://*******.com/264h9v
ORIGINAL: jcd_27265
John
John
http://www.pacificbattery.com/batteryminder.html
[IMG]local://upfiles/45502/F013B383D7DF4C1AA83CDDCD98B5EF7A.jpg[/IMG]
Harley sells the Junior model for more than you can buy the real deal....
Check out Competition Accessories -- quite often you can get the Battery Tender Plus for less than $40...currently at $34.99
http://www.compacc.com/search.cfm
There is also now a two bank model, but you could buy three regular for about the same price.
Battery Tender stands behind their products as well--no hassle replacement if one goes south...
