New ABS maintenance and upkeep cost?!
RE: New ABS maintenance and upkeep cost?!
What fluid is used, DOT 5? If so, there shouldn't be any additional maintenance except for maybe cleaning the sensor.
For cars that use DOT 3, 4, 4+, the fluid still absorbs moisture. This will effect the ABS when heated under load. This is why you should flush your brake fluid every couple years.
[sm=huh.gif] Yeah, I think this guy is either very uninformed or full of crap. Have you owned any cars with ABS? If you have, you already know there aren't any special maintenace consideration except for bleeding the brakes. I've owned 6 different cars/trucks with ABS. Gone with aftermarket pads, rims, etc. ABS doesn't care about anything but tire skid.
ORIGINAL: Doug45601
......Was even told that anyone who brings the bike in for a wheel/tire change will have to go through a wheel line up and ABS recalibration which adds to the cost..............
ORIGINAL: Doug45601
Stopped at the dealership today...
Sometimes the marketing can get a bit out-of-hand with some dealers trying to sell bikes.
