New Screaming Eagle Outer Cam Bearing Plate
Old 11-29-2007, 11:37 AM
alexcue's Avatar
alexcue
alexcue is offline
Default RE: New Screaming Eagle Outer Cam Bearing Plate
ORIGINAL: dawg
ORIGINAL: alexcue
what would it undertake to add this to an engine? How many hours of labor?
Techs would charge 3-4 hours labor. It would be quicker if you had adjustable pushrods.
Thanks dawg...
Old 11-29-2007, 11:42 AM
cardboard's Avatar
cardboard
cardboard is offline
It would depend on which cams you used etc. It should cost you about 300.00 Labor at a Indy shop. When you have new cam's installed have torrington cam bearings installed in the chest.
Old 11-29-2007, 03:33 PM
quackhead's Avatar
quackhead
quackhead is offline
ORIGINAL: cardboard
to install the torrington bearing do you have to change the cam plate?
Old 11-29-2007, 03:36 PM
cardboard's Avatar
cardboard
ORIGINAL: quackhead
ORIGINAL: cardboard
No the cam bearing are in the chest, or the cases.
Old 03-01-2008, 06:51 PM
chriscalabro's Avatar
chriscalabro
chriscalabro is offline
Reading this thread I found to be confusing. The 07-08 Stock cam plate does not have any ball bearings at all. The new screaming eagle cam plate gives you the ability to use the new high flow oil pump found in the 07-08 stock bikes while retaining the ball bearings found on the pre 2007 cam plates. This is a significant upgrade over stock no matter how you look at it.
Old 03-01-2008, 08:35 PM
Neckball's Avatar
Neckball
Neckball is offline
Look again, no bearings in the SE camplate, just bushings. Go here for pics-
https://www.hdforums.com/m_2610695/tm.htm
Old 03-01-2008, 08:42 PM
hogdoc's Avatar
hogdoc
hogdoc is offline
Cars and import bikes have been using "plain bearing technology" for years. This isnt something HD just came up with decided to test on all of us! V-Rods use it for thier cams also, spin to 9000 RPM's. Never seen a problem in those motors that wasnt caused by the guy that built it!
Old 03-01-2008, 08:55 PM
Dalton's Avatar
Dalton
Dalton is offline
Theres two versions of the 07 and up style cam plate. The SE plate is adirect replacement for the stock 07 cam plate, it is just made of billet and more heavy duty than the stock issue. I am running that in my 120. You can "create a conversion kit that includes the billet or stock 07 cam plate and 07 style higher flow oil pump for pre 07 bikes. There are NO ball bearings in the cam plate itself, it is a "bushing" that the nose of the cam runs in. There are two ways to use the new plate in the older bikes. One is to replace the bearings in the case with 07 style and size bearings and then you can run most any cam you wish, other is to go with an Andrews "N" style cam that works in the pre 07 case inner bearings and has the nose of the cam machined to fit in the new style cam plate and uses the new style roller chain and tensioners. Andrews DOES NOT make a cam plate. What they advertise is a conversion using the new style cam plate which you can upgrade to the SE Billet cam plate..
Old 03-02-2008, 09:59 AM
GasCan's Avatar
GasCan
GasCan is offline
Very well explained Dalton. Following in both Dalton's and PhilM's builds, I too used the SE Cam Plate in my new motor. Great part to upgradewith but add's a few dollars to the cost of cam upgrades. When changing cams, adding a gear drive kit, and a billet cam plate, you can quickly exceed the 1K mark in a hurry.
roussfam
Exhaust System Topics
05-18-2013 06:09 AM
brberk
04-01-2013 02:37 PM
trook
09-26-2010 11:24 AM
Tulsa Rambler
01-29-2008 08:54 PM
Tltrump
13
12-18-2007 03:48 PM
Quick Reply: New Screaming Eagle Outer Cam Bearing Plate
