"N" light flashing
RE: "N" light flashing
check the connections on the nuetral switch....located just behind the chrome transmission top cover. it looks like an old temp or oil sending unit. you can also unscrew it and clean it to see if there is any metal dust particles on it. short of that replace the switch.
No recall. Have the new updated neutral safety switchinstalled. It will be covered under warranty. The part number is 33926-06B. The internal spring has been changed. This flashing condition could also cause security issues while riding. I would get replaced as soon as possible. It could leave you stranded.Have the dealer reference Service Bulletin M-1205.
ORIGINAL: Gutman
