Pewter Paint Question
Old 11-26-2007, 07:13 AM
jharanin's Avatar
jharanin
jharanin is offline
Default RE: Pewter Paint Question
Here's the Dupont tech sheets on plastic refinishing and mat clear additive.
If I knew how to add a pdf file I would send it. PM me and I will add it to an e-mail
Old 11-26-2007, 07:55 AM
turtleman57's Avatar
turtleman57
turtleman57 is offline
Hmmmmmmmm just an idea, what about something like rhino liner? Like I said it was just an idea, but it seems like if it would protect a trucks bed, it just might be the trick for the lowers.
Old 11-26-2007, 09:04 PM
kansasroadking's Avatar
kansasroadking
kansasroadking is offline
ORIGINAL: powdercoater
turtleman - I would strongly recommend having your lowers powder coated becuase of the durability factor. You can match the color and gloss level VERY close and not have to worry about stone chips later! There are semi-gloss and matte finish clears in powder coat as well.
kansasroadking - There IS a powder coating process to powder coat plastic. However, it requires a liquid coating to enhance powder transfer, pre-heating the parts and a special powder that is designed for that application. The cure temps pare obviously much lower for plastic coatings so standard powder coating won't work. Good luck finding a custom coater shop that does that. The technology is still relatively new and as you can see, it requires specialized materials and equipment to apply.
Thanks! you learn something new every day
sounds like it's an expensive process......
Jahillsr
01-19-2022 09:44 AM
gvallanc
02-18-2017 07:22 AM
1cerberus4u
06-01-2009 12:07 PM
cwfore
01-14-2008 08:07 PM
HilllBillly
08-19-2007 03:34 PM
Quick Reply: Pewter Paint Question
