Hi Guys
Quick question to the T/Max educated. When running with the autotune sytem do you check or leave unchecked the AFR override box in the closed loop page.
Unchecked, unless you wish to manipulate the A/F ratio at certain RPMs. For a better understanding go to www.thunder-max.com. There is an installation manual, and a tuning manual that will better explain the features.
