tour pak plate
Old 11-20-2007 | 07:44 PM
MJR's Avatar
MJR
Default tour pak plate
Anyone knowthe thickness the aluminum plate in the bottom of the tour pak? I bought a tour pak off of e-bay and they ripped everything out of the inside. No plate, torx screws, gromets; they evern cut the end of the brake light multilock plug.
So I need to make a new plate just need to know how thick the standard plate is. 3/16 or 1/4??
Old 11-20-2007 | 09:22 PM
MJR's Avatar
MJR
Default RE: tour pak plate
Anyone know?
Old 11-20-2007 | 09:37 PM
bigjohn1percenter's Avatar
bigjohn1percenter
anywhere from .060 to .125 will be think enough, i dont even think the one i made for mine is that thick, dont really need much to stop it from flexing
Old 11-20-2007 | 09:41 PM
gilbos440rt's Avatar
gilbos440rt
It's pretty thin if I remember right, more like a 1/16th of and inch not sure what gauge that would be though, at least thats what it lookslike to me. Maybe someone will chime in tell you for sure
Old 11-20-2007 | 10:05 PM
MJR's Avatar
MJR
thanks guys, I will order a 24" x 24" plate and cut it down to fit. I was guessing it was about 1/8th but not sure.
Old 11-20-2007 | 10:11 PM
Harleypingman's Avatar
Harleypingman
Why not shoot Zanotti's an email and ask for a part number and price? I ask because the OEM plate has a smooth bottom with bolts underneathalready formounting, cut-out for light bar wiring, etc.
I'm a big fan of DIY, but even with a liner the bolt heads may be a problem, exact fit more difficult (for me to do anyway)--just my 2 cents.
Old 11-20-2007 | 10:38 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Had the same problem a friend gave me a naked tourpak I used 1\16 plate and a chunk of cardboard to make a template it worked fine
Old 11-20-2007 | 10:48 PM
MJR's Avatar
MJR
I called an independent shop today they could not find a part number so I thought I would have to make it myself. I didn't think it would be too hard to cut out 19 x 12.5 trapezoid and notch out the corners. So Cal thanks for the information.
Old 11-21-2007 | 01:04 PM
miacycles's Avatar
miacycles
Just happen to have an Ultra in the shop for a complete re-build and re-paint. Plate is .075" thick galvanized steel, so if you are going to use aluminum you will have to go a little thicker to get the same strength/rigidity.
Hope this helps.
Old 11-21-2007 | 02:05 PM
cadman311's Avatar
cadman311
I just order a tour pak king is that some else I should need to look for? And how manyother things do I need to go what that tour pak?
