New Road King Power (96) , vs. Older 88
Old 11-19-2007 | 09:03 AM
Windup08's Avatar
Windup08
Default RE: New Road King Power (96) , vs. Older 88
My dealer was surprised at the low numbers on a stock 96...when they did the "before" dyno run on my 08 Ultra it came out to 61 hp, 73 tq, they said a stock 88 averaged around 57 hp 69 tq.....not a big difference.
Old 11-19-2007 | 05:37 PM
iclick's Avatar
iclick
Compare 88/96 with or without Stage 1, but not one with and the other without. The 96" engine has a meaningful increase in low-end torque, but little more HP. Run them full-out (e.g. 1/4-mile) and there would likely be little difference, as the bigger engine doesn't produce that much more peak HP. Punch from 2000-2500 in 4th or 5th gear and the 96" will likely walk away.
When I rode a demo 2007 RK in August of last year I noticed three things in that short 5-mile ride: The improvement in low-end torque, smoother operation, and clattering in higher gears. The first was impressive enough for me to contemplate selling my '96 RK, which I thought I would never do. I did it only three months later, and I'm still impressed with this engine when properly tuned (PCIII, AC, slip-ons, and a good map). The last was also an issue with my '07 SG but has been fixed by installing IDS.
Old 11-19-2007 | 05:52 PM
BillyO's Avatar
BillyO
I have a Road Glide 95" Stage Two--- Stronger by good bit than a Stock 96"
Old 11-19-2007 | 06:54 PM
redhwk44's Avatar
redhwk44
I have an '06 RKC (88 inch) with slip ons, PC III, and an A/N big sucker stage II with roughly 80H.P. and 80TQ. Recently while on an Iron Butt ride my two buddies had been needling each other about who was the fastest. One has an 07 Ultra with a PC III, slip ons, and a K & N A/C while the other has an 03 Electra Glide Standard with a screaming eagle 95 c.i. big bore. I knew I had know chance against the 95 c.i. but I wanted to know how well the '07 ran, so when they twisted it at 50mph so did I. Well, like I said the 95c.i. ran off like we were sittin' still but the '07 just kind of stayed there just in front of me, and after awhile I realized I was actually gaining on him. Then I saw him look in his mirror and he backed off. when we got home my bud with the '07 spent a little cash to help his 96 out but I still don't think he can run with 95c.i.
Old 11-19-2007 | 07:36 PM
nedster's Avatar
nedster
Just traded my 04 RG in on an 08 RG. My 04 had the stage two 95 kit in it. It ran rather well. I have only tested the 96in for about 15 miles, it seemed a little capped up with everything being stock. But I am looking at the other upgrades that I will get with the 08. Larger tank,six speed, motor black powder coated and a motor that can easily be punched up to a 103. Not to mention the color selection with stripe that actually is lined up.
Old 11-19-2007 | 08:32 PM
turbo54's Avatar
turbo54
ORIGINAL: IceHeritage
well if you actually look HD SE states that the output with just the 103 Kit will be 105 and 103,I have just Cams and I am getting over 94tq and 84hp on my 96
Yep That is what im getting with my 8 year old RG with the mm EFI.86 HP and 94 TQ
[IMG]local://upfiles/3159/4B66BDFC66E2449A897130DFAEE5F174.jpg[/IMG]
Old 07-07-2008 | 11:59 PM
TOMCENTRAL's Avatar
TOMCENTRAL
The gearing on the 07/08s causes about a 10-14% hp.loss on the dyno.The stock 88/96 has similar Hp,but the 96 has higher Tq #s.Regards,Tom
nomad billy
02-12-2013 08:07 AM
12limited
05-08-2012 07:21 AM
NDBadlands4-2
06-28-2011 10:04 AM
6165hd
07-13-2007 11:29 PM
Redhead1
Exhaust System Topics
09-15-2006 11:37 PM
Quick Reply: New Road King Power (96) , vs. Older 88
