timing chain tensoiners
Old 11-22-2007 | 11:23 PM
dw2169's Avatar
dw2169
Default RE: timing chain tensoiners
If a person wanted to stay stock but change to agear drive cam, what would be the best way to go and get rid of the tersioner problem?
Old 11-22-2007 | 11:47 PM
byersmtrco's Avatar
byersmtrco
Had 203 cams installed @ 9500 miles. My cam tensioner shoes were 1/3 worn. Prior to that, I had a VIN check done. The dealer told me that my 2000 had the "updated" cam bearings. When the independant shop I go to had it apart, he found the earlier 99 style bearings in there. Imagine that !! Talk about a mushroom cloud on the horizon. I'm sure glad we caught it. I'm sure it would have grenaded by now.
Old 11-23-2007 | 11:55 AM
Big Peter's Avatar
Big Peter
ORIGINAL: Retired_Ted
If you hear the tensioners, it's too late. They're already worn into metal and it's being ground into little pieces headed for the oil pump. Most don't worry much about them since they trade before it's an issue. For the ones who keep their bikes, 30K is a reasonable mileage to at least have a look. Good oil, meaning synthetic, is a good preventative, if you plan keeping the bike. As for gear drive cams, they are a very expensive alternative. They can make additional engine noise which is why HD didn't do the same. Nothing wrong with the chain drive setup - just another maintenance area.
Sorry Ted, I don't agree on " just another maintenance area "
I hate plastic orange bits and pieces in my filter and oilpump.
At 30K I took the tensioners and chains out ,and installed
S&S .510G gear drive cams.
No more worries and no more maintenance
Greetz Peter
Old 11-23-2007 | 06:09 PM
lecomte38's Avatar
lecomte38
Just finished doing mine this morning. 33k miles on an 02 RK. Outer wasn't too bad but the inner was ready to fail- maybe good for another 5 k before it lunched. I tried to get my local HD dealer to do the job on extended warranty - NO. If they haven't failed, (wrecked chains, cams, bearings, etc) they couldn't do it under a general maintenance inspection. I wonder if I complained about excessive noise it would have been covered?
It is about a 10 hour job for a rookie, no big deal, no surprises, made a brass lock to hold the outer gears. My bike loves me for showing her the respect she deserves.
Old 11-23-2007 | 07:32 PM
relli's Avatar
relli
what noise does it make?? iver got a noise lft side that is VERY intermittent and sounds to me like a lifter.
Old 11-23-2007 | 08:42 PM
fljohn's Avatar
fljohn
Stage I
It does depend on the dealer,as far as the extended warranty,and they should be changed between 25-30 K .
Old 11-23-2007 | 09:09 PM
Retired_Ted's Avatar
Retired_Ted
ORIGINAL: wldbill
I haven't found where HD says it's an inspection item. I've got 25K on my 06 now and 3 more years of extended warranty. I just don't see why I should be paying for the inspection cost. And if they are out of spec I also pay the replacement costs. Doesn't it make sense to not worry about it and just let the sucker blow up?
Actually, it probably does make sense to let 'er blow if you're still under warranty - HD won't pay unless there's obvious damage and I doubt if your dealer will eat 5 hours of labor for good will. If you're far from home, you'll regret your decision. If it were me, I'd inspect and replace them at 30K. If you're handy with tools, it's not that big of a job - you'll need to add adjustable pushrods and some gaskets. Going gear drive is so damn expensive.
Old 11-23-2007 | 09:11 PM
twistedcherokee's Avatar
twistedcherokee
relli, that sounds like the rockers moving side to side. From what I understand, it is a common noise. Mine also does that noise.
Toby
Old 11-24-2007 | 01:29 AM
Comfortably Numb's Avatar
Comfortably Numb
The dealer did mine at the very tail end of my 2 year factory warranty. They were next to toast at 20K miles.
CN
Old 11-24-2007 | 03:43 AM
Big Peter's Avatar
Big Peter
ORIGINAL: twistedcherokee
Is ther any warnig on the timing chain tensoiners going bad? My engine seems a little louder in that area but no clatters or clangs. Thanks
Toby
Read and weep
www.stampedemrc.com/spark/tensioner.htm
Just go for gear drive and S&S cams (complete set)
Greetz Peter
Quick Reply: timing chain tensoiners
