Kuryakyn curved license plate frame
Old 11-16-2007, 09:30 AM
ULTRA Gramps's Avatar
ULTRA Gramps
ULTRA Gramps is offline
Default RE: Kuryakyn curved license plate frame
Thanks iclick, I will be installing that as well as a few other bits this weekend.
Old 02-01-2008, 12:06 PM
rome304's Avatar
rome304
rome304 is offline
its always the simple jobs that become the hard ones spent atleast an hour and a half to complete the job.
Old 02-01-2008, 12:23 PM
HDStreetGlide07's Avatar
HDStreetGlide07
HDStreetGlide07 is offline
Go through the brake light hole using a 1/4 ratchet.
Old 02-01-2008, 12:38 PM
rome304's Avatar
rome304
rome304 is offline
did that big hands in the way.
[IMG]local://upfiles/22213/F41D946BEE5F46F9BCA5986910B4052A.jpg[/IMG]
Old 02-01-2008, 12:48 PM
HDStreetGlide07
Mine wouldnt either but you can use 2 or 3 fingers!
Chris
Old 02-01-2008, 12:53 PM
thall's Avatar
thall
thall is offline
I had a buudy with smaller hands help me
Old 02-01-2008, 02:14 PM
buckwheat's Avatar
buckwheat
buckwheat is offline
Thanks to those of you who've provided the guidance to go through the tail lightas opposed to the fenderup from behind the tire!
A few things to add here from a (very) amatuer wrench-turner (all of this is common sense, but I don't commonly use much sense when it comes to these kind of things...)
First, I highly recommend covering the rear fender with a towel or something that will guard against anything (like the stock license plate, falling screws, sockets, wratchet-wrench, parts, etc.) - I created a hair-line scratch from the old plate.
Second, when you're removing the wiring harnesses from the tail light assembly, keep in mind that each wiring harness has some kind of clip or "lock" of some sort which holds each wiring harness in place. Do not just pull each one out with pliers. This may seem obvious, but Harley puts a gel like substance around/on each harness and its a bit hard to see where each "lock" or clip is on each wiring harness. On the two inner clips, there is a push button on the top/back of the wiring harness clip that needs to be depressed before the wiring harness will release... Pulling the harness without depressing these will damage the harness.
Third, when you're inserting the wratchet wrench through the tail light hole, use caution as you're cranking the light bar bolts, Its very, very easy to slip off the bolt and potentially damage/chip paint, etc. off the tail light hole. This is pretty forgiving as the lense and trim assembly will cover up the effected area.
Fourth (regarding the Kury frame itself). You'll likely notice that the holes in the frame don't align with the holes on the license plate, in addition, the plate itself may be just a bit too large to fit into the frame. Clipping snips works just fine for trimming the license plate, then simplydrill through the Kury frame screw holes.
And finally, (this conventional knowledge brought to you by AKEA), don't tighten each light bar bolt until both are well threaded. Tightening one makes the other far more difficult to align and tighten.
All you pros are rolling your eyes at this post... But considering how many guys took as much, if not more time than I to install, perhaps there is value for the next guy who takes this project on...
For what its worth, this is a good warm-up to more complex (but harmless) things you can do to your bike without ending up in the emergency room or the dealer for "DIY gone bad" projects...
Total time from start to finish - about 1 hour 30 minutes...
Old 02-01-2008, 04:39 PM
G$'s Avatar
G$
G$ is offline
Location: LexVegas, KY...home of fast wimmen & beautiful horses
...welcome 2 da board. Many a folk have had dis same prollem. See post above ^ for proper fix it.
Saguaro
Milwaukee Eight (M8)
04-29-2017 04:16 AM
Twospot
03-22-2017 08:44 AM
avneeshj
09-08-2013 01:32 AM
plutnicki
04-25-2010 05:47 AM
Jrsess
04-13-2008 11:37 AM
Quick Reply: Kuryakyn curved license plate frame
