K & N drip again...
K & N drip again...
Oil level is slightly lower than normal and I am still getting Blow-By. Everytime I search for a solution there are 10 different remedies. The way i see it, I need to somehow vent the oil back into the intake or vent it into a breather/filter, like the old Evo's i had were rigged.
I didn't install the K & N backplate, so, my question is where do i start? Any and all recomendations appreciated.
RE: K & N drip again...
What I did was to tap the holes that come from the breathers down into the intake and put a set screw in it with red locktite to plug the holes. Then I drilled and tapped some holes in the shafts where the breather bolts go and inserted a 1/'8 male NPT to 1/4" barbed fitting and ran lines from each side down to a tee. From there I ran a line down to under the bike and you can hang a breather filter from the end of the line.
[IMG]local://upfiles/13641/1C39974BA2DC4E88B2670D2AF19CCAD9.jpg[/IMG]
[IMG]local://upfiles/13641/DA48E0F0BB784B598EC040455AF6D786.jpg[/IMG]
[IMG]local://upfiles/13641/F4294C40A5AD47DFAE9F9AE2B5BB7CE6.jpg[/IMG]
I took the stock rubber hoses, poked holes in the rubber venturi at about 10 and 2 o'clock, and used little zip-ties to hold the hoses out in front of the venturi. They kind of point up on the ends, toward the top of the filter. I haven't had any problems since I did that.
