Difference between frt and rear wheels?
Old 11-13-2007 | 08:07 AM
Crazycoop's Avatar
Crazycoop
Default Difference between frt and rear wheels?
Whatis the difference between the front and rear wheels for and 07 RK with the nine spoke cast wheels? I acquired two and I want to send them out for chroming but I think they are two fronts or two rears because they are the same.
Help.
Old 11-13-2007 | 09:58 AM
miacycles's Avatar
miacycles
Default RE: Difference between frt and rear wheels?
Bolt holes for rear sprocket should be one size larger.
Old 11-14-2007 | 04:56 PM
rome304's Avatar
rome304
to the naked eye they look identical but the rear holes larger.
Old 11-14-2007 | 05:34 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Maybe this will help? I make Carbon Fiber Wheels. The hubs are direct bolt-up to 00-present FL. Sporster wheel is a direct turn-around. You had better make sure that the hubs are o2 to present. To tell the difference check this hub if I can get it to imbed. If I can not I will post one more down. PS can't too large- look down one. If there is aproblem, call me on my dime, I live in EST 1-866-899-5962 Thanks, H
[IMG]local://upfiles/29413/BABC4F39D597428DA3689760F62189E9.jpg[/IMG]
[IMG]local://upfiles/29413/DAA7C02106CF40929644DBD52BE50136.jpg[/IMG]
Old 11-14-2007 | 05:40 PM
FastHarley's Avatar
FastHarley
Former Sponsor
K? This is an 00 - 01 which will not work but looks the same on the outside.
[IMG]local://upfiles/29413/C5B67B23BF804162A9E9617D1A9DB4F0.jpg[/IMG]
Old 11-15-2007 | 08:46 PM
FastHarley's Avatar
FastHarley
Former Sponsor
When a member put this much time and energy to provide correct information as least you can say you received it!
47Norton
11-29-2016 11:12 AM
thisidworks
Touring Parts
03-24-2016 02:20 PM
Dynaunder
Dyna Parts
01-23-2013 02:57 PM
redmustang1990
03-16-2010 11:24 AM
Boris
02-09-2008 12:09 PM
