Who cares about bearings?
#41
RE: Who cares about bearings?
Just ride it damn thingits obvious no one know whats going to happen I had and 04 rk they said the samething I rode it easy and put several thousand miles on it and its still running, was not a 96 but same concept applies know one knows just each personal theroy
#42
#45
#46
#49
OK, I hear you guys regarding "lugging" and I understand....what I don't understand is 2000 rpm considered lugging. Now, I ain't got a bike yet but I've ridden many(non-Harley) and I think 2000 would be "mid range", especially with the displacement the Harleys have divided amongst two cylinders. What is a "stock" idle rpm? What would be considered "redline"? Just curious...learn me somethin'.....
#50
Also, the lower the RPM the higher the torsional load is on the bearing. I freaked when I had to size some fan shaft bearings which ran 60 RPM. As the RPM increases the load on the bearings is dramatically reduced. More details can be found in any bearing sizing guides.
