O Man Outa gas
Old 01-13-2008 | 09:21 PM
amarzano's Avatar
amarzano
Default RE: O Man Outa gas
Has anyone installed these on a 2008 StreetGlide? It seems like they should fit - but when I look up the numbers in the Harley catalog - they mention 92-'07 Electra, Tour and Road Glide only..
53819-04 and 53842-00B
Old 01-13-2008 | 10:09 PM
maxum96's Avatar
maxum96
ORIGINAL: amarzano
I have the second one on my 08 Ultra. Fits and works fine. Street glide should have the same fuel door as an Ultra.
Old 01-13-2008 | 10:16 PM
PapaTravis's Avatar
PapaTravis
And, if you can't finda barrel key, I heard you can use a BIC pen...
Old 01-14-2008 | 02:56 AM
captjon37's Avatar
captjon37
Bought a blank barrel key for $1 and keep it in the tool bag. No more problem.
Old 01-14-2008 | 03:02 AM
Arizona's Avatar
Arizona
My E-Glide has the push button anyways as it is, so I guess I'm glad I've got it now after reading this, lol.
Old 01-14-2008 | 05:34 AM
relli's Avatar
relli
yep changed to the button after learning anyones key would fit
Old 01-14-2008 | 05:35 AM
SpikeCT's Avatar
SpikeCT
thats ok been there done that... me old job was 55 miles from home! light on no key...... Went into shop found a our vertical had a barrel key tokk it to the gas station with me... worked like a charm....
Old 01-14-2008 | 06:37 AM
sewerat's Avatar
sewerat
I also have the lockable push button one, works well, just have to take the gloves off to open it, I think if it had 2 of the spring clips it might be better. BUt i have also found that the barrel key from my gun safe opens the tank flaps as well.
Old 01-14-2008 | 07:25 AM
piasspj's Avatar
piasspj
I have put one in my '08 Ultra. Only issue is that the spring won't fit.
It usually works fine butis sometimes difficult as the lid won't popopen.
Old 01-14-2008 | 07:27 AM
miacycles's Avatar
miacycles
Any barrel key will open up the gas door. If you want a different look you could put a different dash on. Here's a picture of one we are doing now. It is held on the front by a pop-up gas cap and the rear has a little bracket. Real easy install and really changes the look of the bike.
[IMG]local://upfiles/43503/C0EA1B5DBAF94BE29DE4026A3163A5B2.jpg[/IMG]
[IMG]local://upfiles/43503/7A1F550000B34F49A68DD288F412D34A.jpg[/IMG]
Quick Reply: O Man Outa gas
