Fuel Pak...How do I do a factory reset?
RE: Fuel Pak...How do I do a factory reset?
Remove fuel pac......reinstall stock exhaust and whaterever.......If it's closed loop with 02 sensors, it will restore the ECM to "factory"in maybe 40 miles of normal driving.
If the above isn't possible or if she ain't closed loop, then contact the maker of FuelPac.
And while you are at it you can post here more specific issues you are having and why you wanna restore factory map.
Yes the Fuel Pak hooks up to ECU only. I missed a step in the install of the Fuel Pak ( Did not set throttle position). Now it will not let me go back and reset the throttles position. I need to reset it so I can start from the top and do it right this time.
Finally good info Dodge......I got no experience with fuel pac, but your are correct you need to back up and restore, then set throttle pos first thing.
Trouble is you might need to restore bike to stock values if closed loop.
Post year of bike and any mods to it
Im running the version 12,on an 07directions recommend resetting throttle position any time you adjust throttle cables etc, I have done mine several times, just go back to your first setting and run on through them just like you did in the first place, I have never had a problem, there should be no reason to unhook or reset your Fuel Pack, I have switched mufflers a number of times and changed configeration with out unhooking anything. You might want to check with tech support to determine if the 08 versionadjusts differently because of the wireless controls.
