true duals or not ?
RE: true duals or not ?
ORIGINAL: corgi
Sound also gets better with age. It sounds so much different and better after about 1000 miles.
I installed V&H dual headers yesterday. I already have the Oval V&H slipons. I have 47,000 miles on my 05 RK Custom. The sound at idle is quieter, but when you are getting on the Highway it gets a lot louder. One of the guys I ride with, always rides behind me, says it is a lot louder and better sounding now. I can feel a small amount more power in the upper RPM range. My wife says the bike sounds a lot better from her seat behind me and said I should have done this a lot sooner.
I have a true duals conversion which is basically the same as what you are doing except cheaper. Well, used to be cheaper. The Torres kit cost almost as much as the dresser duals now. Anyway, I did it for the heat issue with the right side pipe. I do know that the sound is different because you get more exhaust on the right side. I think some of the guys call it "stereo" sound.
I did the install myself to save a bit of cash so I could spend it on other things. I also did not get my bike dynoed.
Steve L.
Steve L.
ORIGINAL: BTROUT
I am thinking of installing vance hines dresser duals to go
along with my vh ovals......
And I also agree that you should save yourself a fair amount of money by installing them yourself! Easy job...WITH THE RIGHT TOOLS!!
I won't be able to speak to the true dual part of your question until next week (I had hoped to install them thisweekend but they have not shown up yet) but adding a PCIII this summer did give the bike added muscle. My buddy even commented that even two-up, my bike seemed to smoke his away from lights after the install. I din't think the difference was shocking but it is there. I was running the same set-up as you before.
ORIGINAL: ironhead3fan
How much difference does the PCIII and true dual headers make? I already have the Stage I download, VH slash cuts, and SE air cleaner.
Finished the Dresser Dual install this weekend and took her out for a couple of rides. It did change the sound. At idle it has a slight underwater sound to it but under throttle a deep stereo bark. Overall I thinkit sounds much more potato-potato like than before.
My seat of the pants observation is that if it lost any low-end it is minimal and appears to have more pep at high end but who knows. Each could be an artifact of the new map I am running after the install. Jamie at Fuelmoto sent me a map for the duals. Based on my prior experieince with his maps, I think it might be a bit rich. I will put a tank or two through it and then start modifying if needed.
