07 SG calipers on 96 Rk, which brake fluid
Old 11-11-2007 | 09:09 AM
phat96's Avatar
phat96
Default 07 SG calipers on 96 Rk, which brake fluid
Hey guys, I put onbrake calipers from an 07 Street Glide onto my 96 Road King yesterday , they fit great with the adapter. But, which brake fluid do I use.
HDTech here on the forum says dot 4 is amber in color and dot 5 is purple, when I took the cap off the reservoir I found amber colored fluid but the cap on the reservoir says use dot 5 what do you think.
Thanks
Old 11-11-2007 | 09:35 AM
sugarbear's Avatar
sugarbear
Default RE: 07 SG calipers on 96 Rk, which brake fluid
My 07 touring manual says dot 4
Old 11-11-2007 | 12:46 PM
iclick's Avatar
iclick
The factory fill for the '07 is DOT4, DOT5 for the '96. The two are not chemically compatible, and I've had DOT5 that was not purple, so I would assume it is DOT5 and purge the calipers thoroughly if you plan on using DOT5. But to be safe, I'd purge the entire front system thoroughly to be sure, rear too if you changed it. There should be no remnants of the old fluid, whichever it is, before the final fill. There's nothing magical about DOT4 except it is more compatible with ABS, and I suspect HD was phasing DOT4 in gradually for that purpose. DOT5 compresses 10% more than DOT4, and that is not a good thing with the way ABS works. DOT4 absorbs water while DOT5 doesn't, and that is a mixed bag in terms of which is preferable. I've had DOT5 in my antique car for 25 years without problems, and haven't changed it but maybe twice in that period. DOT4 should be changed every two years or 30k miles, whichever comes first. DOT4 also can remove paint, so be careful working with it around painted surfaces.
Old 11-12-2007 | 02:17 PM
shooter64's Avatar
shooter64
Former Sponsor
I would purge it all with brake cleaner a couple of times and run dot 4, dot 5 is horrible.
Old 11-12-2007 | 03:23 PM
molsen's Avatar
molsen
Shooter, why is DOT 5 horrible? I used it for years on old cars, and liked it with my EVO RK. Just curious.
Cull22420
04-16-2015 09:02 PM
cmosentine
07-15-2012 04:28 PM
oldtech
Wheels/Tires
02-02-2010 05:48 AM
emwolb
06-27-2009 04:33 AM
colt_357
06-10-2009 12:02 PM
Quick Reply: 07 SG calipers on 96 Rk, which brake fluid
