0039 vs 575 cam
0039 vs 575 cam
Hello everyone
I know this site is full of HQ people. Emailed Doug at HQ he said the 575 could be used @10:1.
Just wondering about which one of the two cams would give me the most low & mid grunt. I live in ohio, we do have 93 fuel. I'm worried that it may not be availible when I ride out of state. thx for your feedback. Bob
RE: 0039 vs 575 cam
I believe the 0039 Little more tq 575 little more hp I believe I read that the 0039 has like 4 more ft lbs and the 575 has like 4 more hp on average, there is a lot of info on this on the H.Q. techline you can get to it from the web site and its free. Phil M I believe had the 0039 in his 98" he can probably give you some insite to this as well. His dyno sheet from the 98" was impresive.
RE: 0039 vs 575 cam
Bob:
If Doug said the 575 will work in the 10:1 motor I'd go with that.
The 0039 is suggested for the 10:1 motor because its cam timing builds slightly more cylinder pressure than the 575, so that cam induced cylinder pressure increase offsets the somewhat the difference between the 10:1and 10.5:1 compression.
Frankly, unless you have an extremely sensitive butt dyno, (and I don't), I doubt you would notice the difference between the two.
RE: 0039 vs 575 cam
ORIGINAL: Cabo Bob
thanks asuperheat & dawg
the 575 is another cam from HQ they use it in there 10.5:1 kits. It has 4 more degrees duration. offered chain or gear. Just like the 0039 dawg thx Bob
The 0039 & 575 are different grinds on the intake lobe. Both are available for 99~06 motors, but the 0039 is NOT available for 07 & later motors.
Does that help at all?
Received 7,733 Likes
RE: 0039 vs 575 cam
ORIGINAL: Cabo Bob
Hello everyone
Hello everyone
