Trans oil leak
Old 11-07-2007 | 08:50 PM
Fun Rider 05's Avatar
Fun Rider 05
Default Trans oil leak
On a road trip from Indiana to Oregon I found an oil leak which turned out to be an inner gasket between the engine and trans. The dealer I took it to on the road said it was a small leak and they could fix it but I would be down for 2-3 days or I could grab a qt of lube and keep going and have it fixed at home and sleep in my own bed. Took off with the oil and got home and had it fixed. Took it back 24 hrs later to have it fix again. Two months later at the 10000 mile check up the dealer called and stold me it was starting to leak again and they called HD who told them they were having trouble in the castings and they are now in the progress of replacing cases. The bike is an 07 ultra classic and you can see the gasket on the right side but the leak was underneath. Just a heads up.
Old 11-07-2007 | 09:00 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: Trans oil leak
Strange - you ain't the first one ah've heard with the problem, but it must be sporatic 'cuz mahslef an' 2 other buddies all have '03 UC's, an' none of us has had a problem with that (so far).
Old 11-07-2007 | 09:11 PM
Keener's Avatar
Keener
My '05 UC leaks in the same spot. About 2 drops everytimeI park it. Pisses me off!
Old 11-07-2007 | 09:46 PM
Fun Rider 05
That is how mine started.
Old 11-07-2007 | 10:03 PM
voodoodrug's Avatar
voodoodrug
2007 tranny/engine gasket leak
check this out.
have postponed getting it fixed. Funny that you posted this cause today I just made a call to bring bikein on the 19th. It was just getting to me[&:]
Old 11-11-2007 | 11:39 AM
Big Peter's Avatar
Big Peter
ORIGINAL: Fun Rider 05
You can try putting some Lucas stabilizer
in the tranny when the leak is only minor.
It works for me !
Greetz Peter
Old 11-11-2007 | 02:59 PM
rocknrod's Avatar
rocknrod
ORIGINAL: Geoseismic
I think you all should start a poll: Those who have the leak, and those that don't. Then ask of those who have the leak, who is running synthetic oil? Who is running dino oil? I think you will all be suprised at the obvious answer. Issues with synthetic oil leaks have been around since people first put synthetic in an internal combustion engine. manufacturers have improved gaskets and fittings, but the problems still exist.
https://www.hdforums.com/post.asp?do...amp;toStyle=tm
mgoblue3
06-18-2009 06:52 PM
sifularson
06-03-2008 02:36 PM
ddsglide
05-07-2008 08:47 PM
phillaf65
03-13-2008 05:20 PM
jkirisits
09-23-2006 06:20 PM
Quick Reply: Trans oil leak
