Cold Weather Oil
RE: Cold Weather Oil
Any 20-50 synthetic should be fine. Synthetic oils do not thicken up in low temps like petrolrum oils do. Also flows more quickly to bearings and critical engine parts on cold start up. Brand is strictly a matter of preference. I've used Amsoil and Syn3 with no noticeable difference between them. Amsoil is generally considered the best, but the whole issue of which brand oil to use is over hyped and rife with misinformation.
ORIGINAL: Taterdog
Lost1 is 15W50 a full synthetic? I'm running Mobil 1 Vtwin 20W50, but it also has more zinc than most oils, which is good for bikes. Just wonder how the 15W50 compares to the Vtwin oil.
From Mobil's website:
Mobil 1 15W-50 exceeds warranty requirements for gasoline engines where an API certified oil is specified. It meets: [*] API SM/SL
[*] Requirements for Diesel Powered Vehicles where an API CF or API CD is recommended
[*] Provides extra anti-wear additive for older vehicles
[/ul] Mobil 1 15W-50 is formulated with SuperSyn, an extra-high viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications such as towing, hauling and racing. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired. Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles.Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
Chemically I believe it's almost identical to the V-Twin oil, with the V-Twin having slightly more calcium. It meets H-D's "specs" as it is rated CD/CF for diesel engines, which is a suitable API classification per the owner's manual.
I get the 15W-50 for $20 for a 5 qt. jug at Wal-Mart ($4/qt.) vs. approx. $9/qt. for the V-Twin at AutoZone.
Both are great oils and will take good care of your engine...
mchertel
02-02-2022 08:40 AM
fireaxxe
Oil Archive (no new posts)
30
02-17-2020 04:51 PM
