Axle Nut Torque Adapter
Old 11-14-2007 | 06:02 AM
chornbe's Avatar
chornbe
Default RE: Axle Nut Torque Adapter
ORIGINAL: iclick
ORIGINAL: Barton
For those of you who have the Axle Nut Torque Adapter (HD-47925) , where did you get it?
FWIW, you can buy a 36mm socket from Sears for $9 ( http://*******.com/2dv5kf ). Break the nut with this socket, then remove it the rest of the way with the 36mm wrench in your tool kit or a large crescent. I have no trouble using a torque wrench and this socket on my SG, although you can't remove the nut all the way with a ratchet since the muffler is an obstruction. You could move the muffler, but who wants to? Get it tight with the tool-kit wrench, then torque it with the socket.
+1
Plus, the offset pivot point on those wrenches changes your torque amount. Not by much, but it does change it.
  #32
Old 11-14-2007 | 11:18 PM
gman's Avatar
gman
Just noticed that J&P has one that ratchets with a padded handle to prevent scratching. Still has the hole for the torque wrench. Price was $45+.
djdiver157
Wheels/Tires
06-01-2017 12:13 AM
djdiver157
Wheels/Tires
05-30-2017 03:42 PM
Tucker99
05-01-2014 01:15 PM
LockNut
04-18-2007 12:22 PM
Grendel UK
10-31-2006 11:39 AM
Quick Reply: Axle Nut Torque Adapter
