Where do you buy Mobil 20/50 V-twin??
RE: Where do you buy Mobil 20/50 V-twin??
A friend of mine is a mechanic and he has a saying when it comes to oil. "Oil will only break down once and I never let my oil breakdown". So keeping that in mind I use v twin and go about 5k between changes, If I use any other synth I will go 3-4 k depending on what I use. My sister used to be a chemist for Castrol and she said that the motorcycles oils are made to run hotter and not to breakdown as fast. But in a pinch if you need to change your oil and cant get a compatable grade use what you can get but change it sooner than you normally would, and don't let it breakdown.
ORIGINAL: dv102
...My sister used to be a chemist for Castrol and she said that the motorcycles oils are made to run hotter and not to breakdown as fast.
Ah tend to agree in that most of the "m/c" oils jest charge more fer the picture - but ah WILL say ta check the oil specs in yer owners' manual an' make SURE that any oil ya choose meets or exceeds those specs. Buddy's Deluxe - changed the oil in it last night, it says that if ya can't git HD oil, ta use a DIESEL rated oil meetin' certain ASE grades - so jest check it afore ya do it!
ORIGINAL: dv102
... My sister used to be a chemist for Castrol and she said that the motorcycles oils are made to run hotter and not to breakdown as fast. But in a pinch if you need to change your oil and cant get a compatable grade use what you can get but change it sooner than you normally would, and don't let it breakdown.
I couldn't find it at the local Walmarts in the area either,until I found out where they hide it. It is not in the auto oil secton. Look in the motorcycle section. Yep, they have one, about 4 shelves tall and 5 ft wide. Sell gloves, some filters, and a few other items, local WW keeps it on the top shelf. Near the auto section.
