GMR's 107 Kit
RE: GMR's 107 Kit
Should be nice, but I bet you do not end up with the R&R camplate and a Fatcat.
I tried and the pipe will not work with a FatCat. I jacked with it for 6 months and tried several iterations of the coverplate. I finally had to choose between the camplate and the pipe... I chose the pipe.
No biggie... that will save ya $700.
RE: GMR's 107 Kit
ORIGINAL: PhilM
RE: GMR's 107 Kit
ORIGINAL: Cycleman6
Man...That sucks. When I ordered it, Steve asked me what pipe I was going to run and I told him the Fat Cat, so he said he would have to order the slim cover from R&R so that it will work..So Phil are you saying that it won't work even with the slim cover from R&R?
Here are a couple pics of mine, with the new "slim" coverplate. As you can see, the rear headpipe hits the coverplate and holds out out away from the tranny bracket. Initially, they were saying "it's just the heatshield & all you have to do is notch it", but as you can see... it's more than just the heat shield.
I suppose it's possible that the 08's are different, but I don't think that's the case ~ I know the only difference in the pipe is the tranny bracket. Whatever ya do, don't let anyone convince you to "crease" the pipe for clearence!
[IMG]local://upfiles/8665/CA76E94D2F514296826DEFCB22A5296A.jpg[/IMG]
[IMG]local://upfiles/8665/8052EAB29F9F4BBC8B467768945ED84C.jpg[/IMG]
[IMG]local://upfiles/8665/583707A3BA974E70AAAF1D5CD012AABB.jpg[/IMG]
RE: GMR's 107 Kit
ORIGINAL: PhilM
You are welcome!
ORIGINAL: Cycleman6
