GMR's 107 Kit
RE: GMR's 107 Kit
ORIGINAL: PhilM
I think he used to, but is now just boring the stock jugs to 3.93x"
RE: GMR's 107 Kit
Just got the bike tuned and did a dyno pull. GMR build put down
116tq/101hp
Whatcha guys think? I don't have the sheets yet as I had to drop it off and tuner just called me with the results.
BTW, I do have the R&R cam plate AND D&D Fat-Cat...Yes, Phil it does take work to make it fit!!
116tq/101hp
RE: GMR's 107 Kit
ORIGINAL: Cycleman6
116tq/101hp
116tq/101hp
I think there must be a difference in tranny bracket on the 07 / 08's that allow it to work. There is now way it would work on my 05, w/o denting or bending the pipe.
RE: GMR's 107 Kit
ORIGINAL: PhilM
THat's great! 116ft/lbs of torque will be a blast on ANY bike!!!! Congrats!!!!
ORIGINAL: Cycleman6
116tq/101hp
116tq/101hp
RE: GMR's 107 Kit
Congrats on the build cycleman. It sounds like a nice combo you got there. Did you ever find out which heads you have.? Were they R+R ported stock one or other. The tq number is nice, but wonder why the HP is a little low. Which tuning device did the tuner use? DTT? SERT?
Nice job on keeping the Camplate and pipe!
RE: GMR's 107 Kit
Understood Phil, and I'm on the same page as I don't want to start hacking away at a brand new pipe to fit this R&R camplate. If it's the heat shield that's one thing, but having to cut and reweld the pipe is a major pain in the a$$, especially when my bikes three hours away from anywhere I can weld it, and I don't feel like jockeying the pipe back and forth to get it fitting. Simply ain't worth the headache.
I better check with Steve tomorrow regarding this plate and the pipe cause he was ordering the pipe for me with a quiet bafle since Bart only had the standard baffle. I'm seriously thinking of some T-rex or Rinehart pipes at this point? Pipes are getting on my nerves, wait....maybe it's just that I quit smoking last Monday. Yes i'm a bear this week.
I would have thought that if there is an issue with the Fatcat fitting@ 1-3/4" diameter, then the Boarzilla at 1-7/8" to 2" on the head pipe might have more of an issue unless they have redesigned it somewhat? Can anyone confirm the difference or if it will fit the R&R Camplate? Ohhhhhh Steve?
RE: GMR's 107 Kit
If shimming the rt floorbd is part of the equasion, then it sounds like the tranny bracket is also being shimmed. If those are both true, then what happens at the hanger in the back? Either it will have to be moved to the right, or the muffer has to be installed @ an angle ~Neither ofwhich are acceptable options for my scoot.... [&:]
I'd loose the camplate before choosing a different pipe... but that's just me.
