Primary Chain
11-05-2007, 02:11 PM
Primary Chain
How tight should the primary chain be on an 06 roadking classic?
It's a pain to get at through the inspection cover, is there an easier way?
11-05-2007, 02:15 PM
RE: Primary Chain
Your service manual will give you the specs for your chain. Through the inspection cover is the easy way.
11-05-2007, 02:16 PM
RE: Primary Chain
YEA THERES AN EASIER WAY .. TAKE OFF THE ENTIRE PRIMARY COVER
11-05-2007, 02:17 PM
RE: Primary Chain
1/2 TO 3/4 PLAY IS THE RIGHT TENSION
11-05-2007, 02:19 PM
RE: Primary Chain
Tank you much for the speedy responses
11-05-2007, 03:45 PM
RE: Primary Chain
I sure wouldn't call that the easy way.
11-05-2007, 05:09 PM
RE: Primary Chain
Don't forget to check freeplay in several spots.
Put bike in 5th gear and turn rear wheel ,since every
chain has a tight spot !
Greetz Peter
11-05-2007, 05:18 PM
RE: Primary Chain
Quote:
ORIGINAL: oneshotdog
That free play is the top of the chain. Not the bottom laying on the shoe.
11-05-2007, 06:02 PM
RE: Primary Chain
their is a tool but i cant remember who makes it you take the inspection cover off and the tool has measurements on it. or you can put a automatic adjuster on it i went with the HD one and installed it my self it cost about a hundred bucks
11-05-2007, 06:04 PM
RE: Primary Chain
probably go on google and type in primary chain adjuster tools and see what happens
