How to drill out stock mufflers?
Old 12-19-2005, 10:53 PM
toddreber's Avatar
toddreber
toddreber is offline
Default How to drill out stock mufflers?
Have an 06 Street Glide and bought a set of OEM 05 pipes that fit the glide.......they were $40 with shipping. Going to try and drill them baffles out..........does anyone know how/what is needed to do this......Kinda broke/poor mans screamin eagle. Todd
Old 12-19-2005, 11:03 PM
KBES BAGGER's Avatar
KBES BAGGER
KBES BAGGER is offline
Default RE: How to drill out stock mufflers?
I never looked at my mufflers on my bagger, but for my sloptial I made a drill bit for that, I took a 1 foot rod ground 6 side's on the base of it (for the chuck to hold) and welded a 1" whole saw on the other side. Worked like a charm. I drilled out 5 or 6 set's of mufflers with it. But you should buy real mufflers ASAP.
KB
Old 12-20-2005, 06:37 AM
D1LD's Avatar
D1LD
D1LD is offline
if you are in seattle area PM me i can probly do it for ya
Old 12-20-2005, 09:22 AM
bountyhunter's Avatar
bountyhunter
bountyhunter is offline
don't waste your time
Old 12-20-2005, 10:12 AM
DragonNester's Avatar
DragonNester
DragonNester is offline
On my other bike (Triumph) I used a 1/2"X12" bit extender and a 1" step drill bit (uni-bit). It worked great -- the step drill doesn't grab like a hole saw does. It's made for thin metal hole drilling.
Old 12-20-2005, 11:15 AM
lil_gmac2's Avatar
lil_gmac2
lil_gmac2 is offline
Here's my .02 centsIf you drill out your mufflers you will not be happy and you neighbor will not like you. Your bike will be very loud to the point people may not want to ride behind you. If money a issue go for it but if you have about 250 buck you can get some samson slip on they sound great. Good look
Old 12-20-2005, 08:45 PM
mtgriz's Avatar
mtgriz
mtgriz is offline
I've got to agree with those saying don't bother with it. I went through this exercise on a dresser I had in the 80's. First drilled a few .25 holes in the rear plug, then a couple more holes in the front plug, and then I finally took a hole saw and drilled out both plugs so I was finally just straight through. Neighbors that came by to visit that night thought I was nuts. Final result was the bike had sort of a hearty chug, chug sound to it.....maybe more like rap, rap, rap. Sounded grim. Put a pair of Cycle Shack slip-ons on and couldn't have been happier. ymmv, of course
Ken
'01 FLHT
Old 12-20-2005, 10:44 PM
Mood Swing's Avatar
Mood Swing
Mood Swing is offline
I was going to do this too.I had 3 pairs of stock slip ons to experiment on,but just came across a V&H Propipe for 200 bucks.I'm gonna do that instead.
My advice,wait,and maybe find a used set of better exhaust.
Old 12-20-2005, 11:23 PM
swb's Avatar
swb
swb is offline
On the 2005 touring mufflers, there is a middle plug/plate on the front and rear of the mufflers. I drilled both out, using about a 1/4 inch bit (it took several passes to get most of the plug out). The back ones were easy, but the front ones took a long bit. I forget how long, but you can measure using a wire. I did not do any other adjustments to the baffling and they sound pretty good. They are not too loud and I have very little popping. Let me know if you have any additional questions.
PopsHD
2014-2023 Touring Models
43
07-16-2019 11:54 AM
badcooky
Milwaukee Eight (M8)
10-22-2017 04:38 AM
djodrey
01-27-2016 10:48 AM
RonT
06-12-2011 07:50 PM
Howard
Exhaust System Topics
10-25-2007 03:31 PM
Quick Reply: How to drill out stock mufflers?
