Check Engine light
Old 02-29-2008 | 04:08 PM
twincam47's Avatar
twincam47
Default RE: Check Engine light
ORIGINAL: FastHoss
I have always heard to avoid trouble with ecm to turn ignition on and wait untill check engine light goes off,then start.Anyone else know about this? Four years and never a problem.
MYTH.....jsut turn the ignition on and hit the button
Old 02-29-2008 | 04:56 PM
Scootr's Avatar
Scootr
Great info Greatguy thank you.
Old 02-29-2008 | 04:58 PM
Scootr's Avatar
Scootr
ORIGINAL: twincam47
ORIGINAL: FastHoss
Agree. Especially if you add a Power Comander it starts better if you hit the starter before the light/fuel pumpgoes off.
Old 03-02-2008 | 11:10 AM
racklefratz's Avatar
racklefratz
ORIGINAL: FastHoss
"Trouble" wasn't with ecm. Trouble was bad handlebar switches; ecm was/is fine.
The check engine light comes on with the ignition as part of a number of self-checks the system performs. There's a data bus throughout the bike's electrical system and data is sent around everywhere on the system to try to be sure stuff is working. HD techies call it "housekeeping". The bike will start fine whether you wait for the check routine to finish or not. I usually wait till it's done; I'm seldom in that big a hurry.
Old 07-02-2009 | 10:13 PM
ucommbxny's Avatar
ucommbxny
in the middle of a road trip this week to the blueridge parkway my cruise control started to act up then the check engine light came on, checked error code P0577, so i would have to say it was the cruise control that set off the error code. if the codes are standard at least for cars that code indicates cruise control problem, will bring to dealer to have fixed under warranty
Old 10-13-2009 | 06:38 PM
dlind24's Avatar
dlind24
Stage IV
My 09 Classic did the same. Replacing the handlebar switch. we will see
HOGILAC
03-10-2014 01:44 PM
Pog Mo Thoin
08-12-2013 12:07 AM
Newharleylover
Exhaust System Topics
07-01-2013 07:41 AM
SoFla
"The Florida Crew"
58
12-19-2009 11:18 PM
Harley Dave69
05-07-2008 06:56 AM
