CAM Chest replaced, now bad gas mileage?
I had the entire cam chest area replaced under warranty two weeks ago with stock components...before the replacement I used to get 39 to 41 MPG...I just filled up this afternoon and got 28.8 MPG? Highway miles have been averaging around 34 before today.
The bike actually runs stronger now since the cam change? Is it possible they put the wrong cams in? Maybe the timing is off?
Is there a sensor that could have been damaged during the cam replacement that would affect mileage?
RE: CAM Chest replaced, now bad mileage?
Things may be just a wee' bit tight and the milage is not all that off. I'd keep an eye on the amount of oil in the cases and check the plugs to see what they are looking like. Check your milage on the next couple of fill ups and be consistant with the amount of gas and the calculations.
Also buy the gas from the same station if possiable. Keep in mind the winter months gas formulas change across the country and you will get worse milage.
what exactly happened to your bike as to need cam chest replaced?
the reason i ask is because i have an 05 rkc doesn't seem to have any problems in that area yet
just wondering how the warrenty would work if i ended up with the cam chains problem or start using
oil as some of the 05 bikes are prone to do.
I had a non rythmic metal popping noise coming from the primary side, at first they thought it was the compensator sprocket but later ended up being the cam bearings...it ate up the cam plate as well.
The tensioner shoes were almost in perfect shape after 30K miles.
I asked them to install SE203 cams but they said I should stay stock for now and not have warranty issues later on? Maybe they F'ed up and put the 203's in?
The bike is EFI with a power commander and a map from the fuel motto guys (Jamie).
I've cleaned my K&N filter and put new spark plugs in and have run five tanks of gas through from only two different stations...I always fill up till the gas reaches the neck of the filler, takes a bit more effort but gives me more acurate MPG's.
Yes the genius' at Adamecs worked my ride...[:'(]
ORIGINAL: pled55
If there is damage already done because of the tensioners breaking,then the repair would be covered under warranty.
ORIGINAL: 1FLTRI4ME
I spoke to a service writer today about the cam chain tensioners.If they do an inspection and find they are worn out,you will have to pay for the repair.
ORIGINAL: pled55
www.stampedemrc.com/spark/tensioner.htm
Greetz Peter
ORIGINAL: fryeca
From the little info you can send on the web, I'd guess that unless you have a major change in performance that can be cam related there's another problem. How did the old plugs look when you took 'em out, & have you checked the PC-III current map with the one Jamie sent you? Since you have a clean filter & new plugs, I'd look at fuel flow next & that's controled by the PC-III map.
