Road Glide ignition switch removal
Old 11-03-2007 | 04:14 PM
glook1's Avatar
glook1
Default Road Glide ignition switch removal
I recently bought an 01 Road Glide and am taking it apart for some new paint. I've hit a snag in the road with taking the ignition switch off so I can get to the screws that hold the inner support fairing in place. I'm sure there is a trick to it but I am new to the touring group family. Can someone tell me how to get just the chrome part of the ignition where the key goes in off?
Thanks in advance for the help....Glook1
Old 11-03-2007 | 04:24 PM
Biggzed's Avatar
Biggzed
Default RE: Road Glide ignition switch removal
Not sure if the same procedure applies to your '01, but here is how you get the switch off on my '07 according to the service manual (i'm paraphrasing below):
1) Insert key into switch and turn to the unlock position. Leave key in.
2) Turn the forks to the left fork stop and rotate the swtich to the FORK LOCK position
3) Depress the small release button at the bottom (left side) with a small screwdriver. Push key down and turn 60 degrees in a counterclockwise direction.
4) Lift straight up.
I've done it once and it's pretty simple.
Old 11-04-2007 | 12:07 PM
glook1's Avatar
glook1
Biggzed is the man!!! Worked like a charm. Thanks
Old 11-04-2007 | 03:43 PM
hd2007's Avatar
hd2007
Getting it back together can be a mother #$@# If it don't slide down into position use a thin screwdriver to move tumblers in a straight line . Make sure you post some pics of that new paint.
Rickr01
04-19-2017 09:40 AM
Kingodivin
Harley-Davidson Street
03-08-2016 11:48 AM
shovelheadred
21
02-04-2014 07:29 AM
jsimo7
12-27-2012 03:50 PM
Gliden
01-02-2012 04:23 PM
Quick Reply: Road Glide ignition switch removal
