HELP!!! PCIII TROUBLE
Old 11-21-2007, 10:55 PM
Peyts's Avatar
Peyts
Peyts is offline
Default RE: HELP!!! PCIII TROUBLE
Could you bring your laptop in tomorrow? I'll send you a text. Thanks for reminding me!
  #132
Old 11-22-2007, 09:59 PM
Peyts's Avatar
Peyts
Peyts is offline
WELL, WELL, WELL... I got the PCIII installed and the Stage 1 complete(finally).
I reinstalled the SE high flow air cleaner assembly and the PCIII. I installed the O2 sensor eliminators. I set the 0 throttle setting. I downloaded and installed Firmware update 2.2.2. I downloaded and installed Firmware update 2.3.0. The bikefires up and sounds pretty good... I can't ride it now, though, on account of the snow on the ground.
I'm hoping that the snow melts and I can take her for a quick jolt on Saturday... supposed to be sh*tty again on Sunday, with more snow enroute.
Is there anything else that I need to do?
  #133
Old 11-22-2007, 10:42 PM
YodaddyKeith's Avatar
YodaddyKeith
YodaddyKeith is offline
Yep, install rear track and front ski.
  #134
Old 11-23-2007, 07:59 AM
Peyts's Avatar
Peyts
Peyts is offline
EXACTLY! Hahahahaha!
  #135
Old 11-23-2007, 09:25 AM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
ORIGINAL: Peyts
I don't think you want to install the 2.3.0.0 ignition firmware on a Harley.
  #136
Old 11-23-2007, 11:14 AM
skratch's Avatar
skratch
skratch is offline
Received 4,357 Likes on 2,536 Posts
there are two firmware updates 2.3.0.0. one says 'fuel firmware for all pciii usb except harley davidson', and the other states 'ignition firmware for all pciii usb. they are different sized files, so i assume they perform different functions. i hope that you don't have to reflash back down. flashing firmware is always a sphincter puckering event, if something goes wrong, you end up with a nice brick.....
  #137
Old 11-23-2007, 11:37 AM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
ORIGINAL: skratch
I think if you install the 2.3.0.0 ignition firmware after the 2.2.2.0 Harley firmware, the mode of operation changes. Been down that road.
  #138
Old 11-23-2007, 12:15 PM
sifularson's Avatar
sifularson
sifularson is offline
ORIGINAL: BadBobOk
ORIGINAL: skratch
Just be sure you have a fresh 9 volt battery. Also make sure your laptop is fully charged or plugged in. I made mine a brick when I used the ignition switch rather than the 9 volt. Had to send it back to Dynojet to have them "revive" it.
BTW, I'm not sure if you even need to update the firmware. Call Dynojet and ask them if it is necessary. I should have the answer but I don't. Shows how smart I am.
Steve L.
  #139
Old 11-23-2007, 07:28 PM
Peyts's Avatar
Peyts
Peyts is offline
I haven't ridden the bike yet (as snow on the ground here), but it did flash up yesterday after the update.
Further, the 2.3.0 update said it was for ALL PCIII USB. Don't know what it does... but it is on there anyway.
I am hoping that the streets will be snow clear by tomorrow, and that I can take her out for a spin. I'll report tomorrow.
Cheers, gang!
  #140
Old 11-23-2007, 07:43 PM
oldhippie's Avatar
oldhippie
oldhippie is offline
Peyts, chances are it'll run great, but remember you are prolly talking close to 0'C (freezing) temperatures right now. It will be Spring most likely till you are able to get that bike up to normal running temps. When that happens, you may want to make some tweaks to low rpm/low throttle opening section of the map (upper left corner)where the moco runs it at 14.7 to satisfy the EPA.
I needed to add a bit to some of the cells there to cool the heat down. Now, I'm backing it off some so I'm not running too rich, but I'm not doing much now since it's so damn cold here anyway the bike isn't making it to 180'F on the oil temp guage. When it normally runs steady state about 220~230F during warmer months.
I'll bet you're going to feel like you gianed another 10hp and ft/lbs.
Quick Reply: HELP!!! PCIII TROUBLE
