I can't tell you the number offhand but I can tell you they are a huge improvement over the stock pads. Got rid of the brake dust problem and the brake squeal.
I put a pair on my V-Rod at about 11k miles. The pads are the same part number (and calipers) as the touring bikes. What a difference! Quieter, much more progressive stopping power, cleaner, and were much easier on my polished rotors. I'll be putting a set on my Road Glide over the winter. I found them online for a couple $$ less that Drag Specialties, or even directly from www.lyndallracingbrakes.com, but after adding shipping, the best price was at my local dealer. Go figure.
Yes, the number 7195 is correct. Just add the letter Z or G (for Gold). Lyndall R.B. thru its selected venders such as myself support this site and are currently renning a promotion for your item. Link to promo thread.
$34.55 at Cycle Spot. That is where I bought mine and love 'em (I only did the fronts, will do rear this winter). Much better than stock. I also put floating rotors on.
When my '05 RK Custom was new it had squeel issues with the front brakes. No matter what I tried still there. Apparently this was a wide spread problem back then. Switching to Z-Pads cured that and no more dusting. I eventually put them on the rear to stop the dusting there as well. I give them a thumbs up for quality and wear.
