What is the 3 wire connector on the radio Antenna
Old 11-01-2007, 07:09 PM
agapsdiver's Avatar
agapsdiver
agapsdiver is online now
Default What is the 3 wire connector on the radio Antenna
My brother has a 2006 EG custom with a removabletour pak.
The radio antenna connector at the rear (coming from the radio)has the normal antenna connection, but also hasa small three wire black connector attached to the antenna wire, a blue, a brown, and some other dark colored wire. It's a female connector with all three wires in line. Anyone know what this connector is for???
Thanks..
Old 11-01-2007, 09:01 PM
sifularson's Avatar
sifularson
sifularson is offline
Default RE: What is the 3 wire connector on the radio Antenna
I want to know too.
I just put a hidden tunetrapper antenna on my bike so I removed the rear antenna and coiled the wire under the seat. I noticed this plug too especially when it got caught and would not come out of a tight spot near the shock.
I suspect that the wire has something to do with rear speakers, or tourpak lights???? Only a guess.
Steve L.
Old 11-01-2007, 09:04 PM
agapsdiver's Avatar
agapsdiver
It's not for the speakers.....the speakers have their own wires....
Anybody ...Please...
Old 11-01-2007, 09:24 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Veteran: Marine Corp
Received 24,870 Likes on 9,333 Posts
That's your connector for lights on a tour pac.
[IMG]local://upfiles/14260/540D87F56AB7497FB401F4F5E3B2D6CF.jpg[/IMG]
Old 11-02-2007, 02:08 PM
agapsdiver's Avatar
agapsdiver
My brother's quick release tour pak doesn't have lights... but he would like to add them.
I assume since there are only three wires these would be a ground, running "tail" light, and brake light.....no turn signals.....
Is this right???
Old 11-02-2007, 04:01 PM
Blueslover's Avatar
Blueslover
Blueslover is offline
It's for TP lighting. Should be run/brake/ground.
Old 11-02-2007, 09:22 PM
EasternSP's Avatar
EasternSP
I did a spoof thread about installing the tour pac lighting kit back in April. It's pretty easy.
https://www.hdforums.com/m_1447481/tm.htm
Old 11-02-2007, 10:20 PM
agapsdiver's Avatar
agapsdiver
EasternSP - Thanks... i'm going to send the link to my brother...
he uses about the same tools as you, so it should help..
Old 11-02-2007, 11:03 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Don't forget to send him the JB Weld.
vman99
2014-2023 Touring Models
01-08-2019 04:06 PM
just plain john
Audio Systems
09-26-2014 06:30 PM
tankplunkett
04-17-2013 04:35 PM
sdoomaha
Audio Systems
04-29-2012 06:33 AM
BigFokker
08-30-2008 11:39 PM
Quick Reply: What is the 3 wire connector on the radio Antenna
