Hogg Chopps-Are they worth the money?
RE: Hogg Chopps-Are they worth the money?
I have a set of these on my Street Glide, color matched Black Pearl like Sped. They are indeed talled than the HD ones and sit forward of the engine guard compared to the factory lowers so there is more foot room. The color matching is spot on. With the fairing side deflectors installed I get very little wind on my knees. The narrow shape at the bottom allows a pretty descent flow to the engine but my lower legs stay warm none-the-less. As for the concerns with the mounting brackets, I don't see that there will be a problem there. The lowers are pretty thick ABS and the clamps are vinyl covered clamps so I don't expect any failures to happen.
Here are a few pics of them installed:
ORIGINAL: bdjhog
ORIGINAL: PapaTravis
They do look great. One question, though. Where the outer part of the lower contacts the engine guard, do you have any rubbing, or vibration in them that causes a noise from them hitting the engine guard? I see it has a clamp on the bottom, and one on top. there seems like it should have a third right at that upper section that looks to come in contact with the engine guard???
