HQ 113"
Old 10-28-2007, 11:28 AM
asuperheat's Avatar
asuperheat
asuperheat is offline
Default HQ 113"
Allofyou diehard H.Q. guys are beating me down, I CAN'T STOP NOW!. From everything you guys say about those guys so far I have found true, I figure I will just do a 95" or 98" but some how just dont think I can stop there. I guess I will have to call tomorow and pin down exactly what im doing but now leaning to a H.Q.113", S.E. 4-3/8 crank, and a H.Q. pro tuner (already have a sert). Just wanted to say no mater what the final decision ends up to be you guys have helped me part with my $$ in my quest for tq on tap!
Old 10-28-2007, 12:14 PM
PhilM's Avatar
PhilM
PhilM is offline
Default RE: HQ 113"
The 113 is a little more up front, but it isa LOT cheaper to do the 1st time around, rather than doing a 95/98 now and deciding to change later. Reason being that the heads are setup for which ever size you select. I had a GREAT set of HQ heads on my 98", but the compression would have been "thru the roof" on a 113 or 120, based on chamber size requirements of the 98 vs 113/120.
End result is that Rocket Jocket now has a great set of heads and I will be having another set done for my new build.
If you "think" you may wanna go with the 113, it might be worth saving a few more $$$'s now and doing it ONCE. Funny hearing that from me, huh!
Regardless of which way ya go, you'll love it!
Old 10-28-2007, 07:41 PM
Manish_Hawg's Avatar
Manish_Hawg
Manish_Hawg is offline
Default RE: HQ 113"
What is the going rate on the HQ 113? I am doing my build soon but I was going to do the 95, if it's in my budget, I will just step up with the big boys.
Old 10-28-2007, 07:54 PM
asuperheat's Avatar
asuperheat
Default RE: HQ 113"
Not sure just yet on total cost the kits are priced on the website but 113" requires casework and crank and I sure a few other things that are done outside of H.Q. and labor unless like me you intend to do the build yourself.
Old 10-28-2007, 07:56 PM
cardboard's Avatar
cardboard
cardboard is offline
Default RE: HQ 113"
I heard its cheaper to do a 107 build than a 113 if the money gits to be the issue.
Old 10-28-2007, 08:01 PM
PhilM's Avatar
PhilM
PhilM is offline
Default RE: HQ 113"
You can go to the HQ site and follow the build tool and get an idea....
http://www.head-quarters-usa.com/sporttouring06.html
Your bike, like mine, will require a new crank. The S/E 4 3/8" (by Jims - not the one that comes in the 07/08's) can be had from Zanotti or Chicago for~ $840.
Like I mentioned above, it's may seem kinda pricey, but not compared to doing it in a less than satisfactory config and then re-doing it, or compared to what something with MUCH LESS results, from a dealership, would cost.
Old 10-28-2007, 08:06 PM
PhilM's Avatar
PhilM
PhilM is offline
Default RE: HQ 113"
ORIGINAL: cardboard
That is true on an 07 or 08 bike, because all ya have to do is bolt on some bigbore jugs & pistons and you have a 103 or 107. Those of us that have pre-2007 motors require a new crank to get beyond 95/98". If one has the cases split to intall a new crank already, then boring the case to accept the BiggerBore (4.060") jugs is not that much different. So.... from that perspective, a 113 really is not that much mre than a 103/107, but the results are a whole bunch different!
Old 10-28-2007, 08:55 PM
SpikeCT's Avatar
SpikeCT
SpikeCT is offline
Default RE: HQ 113"
Im running the HQ95 at 10.5:1 with 575's and she is very strong.... I need to get over to see what she has as the tunning is pretty good. Soooo thats why Phil went to 120 casue my 95 scared his 98.......
lol
Old 10-28-2007, 09:55 PM
Manish_Hawg
Default RE: HQ 113"
I just ran the numbers.....I will be getting the 95.
Old 10-29-2007, 12:52 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
Default RE: HQ 113"
I will be going with the 95", as well. Thanks to Phil selling me his old 95" jugs and pistons. I will say, though, I am a bit nervous about doing it myself. But Phil has told me I should be fine, and even offered to help me via the phone. Thanks, BTW, Phil.
Quick Reply: HQ 113"
