Is the Air Shock Pump ($50) necessary?
RE: Is the Air Shock Pump ($50) necessary?
ORIGINAL: bluto43
How important is it to keep the shocks at pressure if you ride solo?
EDIT: Here are my favorite posts on this thread so far.
Thank god Harley came up with this space aged device
[brewdog]The HD model has a built in gauge and relief to adjust the pressure.
[SGDude]I was going to use a bicycle pump too, but then I looked at the HD one, which you should be able to get for about $30, and noticed the fine gradients and relief valve.
[hd2007]It has a special end that does not allow air to escape when you remove it from the bike , without it you WILL NOT get accurate pressure.
Buy the right tool its worth it.
[bulldogmoe]the one from HD is highly recommended. it can add air in small amounts. it has a gauge on it, a bike pump doesnt.
[prc1333]I would recommend you buy one from HD. It is worth the money to have something that will travel, is light and also has a button to release air, easily and accurately. Bicycles today have smaller fittings than you need and if the bicycle one is worth anything it is 5 times the size and 19 times the weight.
[IronLegend]I would suggest buying the Harley pump as it's made for this particular application, probably a one-time purchase item and I can air-up the shocks easily sans removing the hardbags.
Whoa, hold on. Something with a HD logo and it is not made in the USA...
[corgi]I just broke down and bought the Harley one(15% off). I was using my kids bicycle one, however wanted one for the road. The good news is that its not made in China...It made in Taiwan. I don't mind Taiwan since their a thorn in China's side.(sorry a litle off topic)
[NCCopBikeRider]Works Performance makes the one HD Sells
I'm a strong guy and just can't stop myself at the correct pressure
[cogener8]When these guys are talking about bicycle pumps they are talking about bicycle shock pumps not tire pumps. I have one for my mountain bike and would not reccomend using one for your motorcycle. Most are designed to pump up to much higher pressures than you need. My bike pump goes up to 300 lbs. I really would not trust it at the 20 to 35 lb range on a motorcycle. I spent the money on the harley pump and am well satisfied. By the way the bike shock pumps sell for about the same money as the harley pump.
MSRP: $43.95 Part # 54630-03A
Suspension Air Pump
This pump was designed to allow safe and simple adjustment of the front and rear air suspension on Touring motorcycles. Unlike a bicycle pump or a fuel station air hose, the hand operated pump with controllable "micro bleed" valve allows precise adjustment to air volume, and the "no loss" air connector maintains shock pressure when the fitting is removed. The 4.5" swivel air hose simplifies valve stem attachment. The aluminum housing is compact, lightweight and durable, and fits easily into your bag for"on-the-road" adjustments. The high quality 0-60 psi gauge ensures accurate air pressure.
Here are some options for a suspension air pump which is the same thing being sold by Harley.
The day I hand over $43 for something I can buy for less and with better quality just because it has a logo on it... c'mon people.
For me, I'll shop around and save some money on somethings so I can spend more on others.
[URL=http://www.pricepoint.com/detail/16246-318_SET357-3-Parts-59-Forks/Accessories/Sette-Air-2-ST-35-Univ
Suspension Air Pump
