Wiring Question
Old 10-25-2007, 07:33 PM
Bldr1000's Avatar
Bldr1000
Bldr1000 is offline
Default Wiring Question
Is the Accesory rocker switch already connected to the battery. Can you remove the Fairing and connect to acc switch and it already be hot?. I want to hook my GPS to the accessory switch if possible. Bldr
Old 10-25-2007, 08:18 PM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
Default RE: Wiring Question
Yes, it is already hot. But if all yer lookin' ta power is the GPS, tap off the cig. lighter circuit- it'll carry it easily.
Old 10-26-2007, 06:39 AM
gunnert's Avatar
gunnert
gunnert is offline
Almost any of the assy wires inside the fairing can power a GPS. They are usually color coded Blank and Orange. Check your wiring diagram.
I "think" the assy switch sends power to the connector under the seat. In the bike I'm building with an 04 wiring harness, I traced the power wire from the assy sw/, cut it, and now use it to power the dimmer on the Digital Guages.
Old 10-26-2007, 06:56 AM
TickTock's Avatar
TickTock
TickTock is offline
I tapped into the accessory switch on my FLHX. All I did was get two inline wire connectors and hooked it on the switched side of it. Works great and it kept me from running wires along the frame and kept it all neat inside of the fairing. All you need is a voltometer to determine which side has power when switched on. I didn't even need to remove any part of the fairing cap as you can easily (but carefully) reach up inside to finger crimp the wire connectors.
Old 10-26-2007, 02:52 PM
texan321's Avatar
texan321
texan321 is offline
ORIGINAL: TexasRedneck
The cig lighter is where I powered mine.....
Old 10-26-2007, 03:05 PM
Scorpio49's Avatar
Scorpio49
Scorpio49 is offline
I plan on using the cig lighter for my GPS. How difficult is it to remove the fairing. I do have the manual. Not sure I feel comfy taking the fairing off.
Old 10-27-2007, 02:15 PM
TickTock's Avatar
TickTock
TickTock is offline
Fairing removal is easy. Four screws on the inside and the three across the top. First time through have a helper to unplug the headlight. After that you will be able to do it yourself easy enough.
VA_Larry
2014-2023 Touring Models
11
01-22-2015 01:54 PM
JefFLH
05-15-2011 08:04 PM
Boom
06-04-2010 06:27 PM
StreetKing
03-22-2010 12:35 PM
kennyross
09-28-2008 06:48 PM
Quick Reply: Wiring Question
