Shock Part Numbers???
RE: Shock Part Numbers???
ORIGINAL: Crusher
What is the difference between these shocks????....
54565-97B
54565-97C
54565-97B
54565-97C
the OEM numbers (price is the same)
I found this on the net:
I had a pair of Road King air shocks, Showa 54565-97C on the tag. I went through a zillion suspension changes including using 1 " lowering blocks to get them to work. They did not have oil in the air chamber because it leaked out in shipping. I bought a second pair 54565-97A is on the tag, they work much better, no lowering block needed, down to 2 psi, don't bottom out, good dampening, but a little too much initial stiffness. They do have oil in the air chamber. The 97C shocks weighed 4 lbs, 10 and 12 ozs, the 97A shocks weighed 5 lbs 2 and 3 ozs. I assume the weight difference is the oil in the 97A shocks.
Anybody have any idea what the A and C mean at the end of the part numbers? Are they different applications? Evidently, not all RK air shocks are the same.[/align][/align]Greetz Peter[/align]
ORIGINAL: Big Peter
Still don't know the difference between the "B" and the "C" or what year that part number changed or why. I do believe they may be the same length.
ORIGINAL: Crusher
The"A" is the short or lowering shock that comes on the Street Glide/Road Kingand the "C" is found on the other touring bikes.
hope this helps.
