Polishing engine fins?
The finished edges of the cooling fins on my black engine are getting what looks like spots on the machined surface. I was wondering without paying alot of money, what other people have used to polish the edges of theircooling fins? I don't want to screw up my black powder coat with some polish that won't come off the black if I get any on them. I'm thinking great winter project. Let me what you've used if anyone has done or is doing this.
RE: Polishing engine fins?
You might try some very fine wet sanding. Something like 2000, 2500, or 3000 grit paper. I have done this on a prior ride with good results. On the other ride after wet sanding I used some never-dull polish to finish it off. I think never-dull will leave a residue on your powder coat, but you might be able to remove it with some simple cleaners and a brush. I would test it first on an out of the way area to make sure you can remove the residue. Good luck.
Polish fin ends
Had the problem on my 07 twin cam! Tried sand paper,never dull, mothers alum polish! Nothing worked. Bought a cordless dremel 2 speed and #4 polishing compound(white)stick. With the small polishing wheel I finally got it off. The fins look like new again. Takes some time but well worth the results!
