help with gps zumo
RE: help with gps zumo
I believe that you can. I recently installed my 550 and was told that you can create and modify routes with the software that came with the 550 but I haven't tried it yet.
you might go to http://www.zumoforums.com and look around as they have answers to most every question I've had so far.
Jim
Jim
Load Mapsource from the supplied DVD to your computer, & enter your unlock code (on the yellow card in the paper work with the Zumo). Create routes, waypoints, etc., & download to the Zumo via the supplied USB cable. To download, plug the Zumo into the USB cable (port is on the bottom under the cover), wait for Zumo to go into "mass data" mode, select the download icon from the tool bar on Mapsource & wait for your computer to find the Zumo as a removable drive. Click "ok" & watch it load. After downloading is complete Zumo will tell you it has new data. You must tell it to keep it or delete it. Pretty self explanitory if you take it a step at a time. PM me if I can help.............
Angelina78, Had the same problem with my Z550 kept telling me device was not available. Called thier tech support, took about a 1/2 hr but they walk me thru a software issue,their problem. Works perfect now, would not be able to fix on your own without tech help. call 1-800-800-1020. They guy I had was great.
