Headlight plug on FLHTCU
RE: Headlight plug on FLHTCU
Carefully pull the front of the fairing away from the inner. When I do it on my 2001 FLHTC, I lay a towel on top of the passing lamp/turn signal bar. As you do, you will see the headlight plug on the back of headlight. Pull it off. I usually have to wiggle it a little as I pull it off.
The light plug has a "clip lock", you need to squeeze it and pull for it to release.
I remove my entire headlight assembily from the fairing, and unplug the light. Just use a torx and remove the four screws. Makes removing the entire fairing easier, and you don't have to mess with the small screws inside the headlamp ring. Make sure you cover the front fender to keep from scratching. I also drop my driving light bracket down, makes removing and installing the fairing a snap. Takes two minutes, only four screws.
Good luck
SteveO
Good luck
SteveO
ORIGINAL: SteveO
Oh well, I needed to upgrade the bulb anyways.
DBLXX
2014-2023 Touring Models
14
03-17-2014 08:09 AM
