07 FLHTCUSE2 Slip On's on 07 FLHTCU
RE: 07 FLHTCUSE2 Slip On's on 07 FLHTCU
I bought a set of take-off '07 CVO Ultra mufflers that you referenced and stuck them on an '06 Ultra with a 95" build that I had. The FLHTCUSE mufflers are catalytic and hurt the performance as felt in riding and verified on a dyno. The dyno tuner said they had too much back pressure. . . but they were very quiet if that's what you are looking for..
Thanks for the info. They are quieter than I expected. Thought that coming off of a 110" motor I'd get more breathing due to the 15% difference in displacement.
I put the HD heat shields on last summer which helped.
An article referenced on the forum stated going to a straight dual system (a la the Rinehart "True Duals") would hurt low rpm performance but I guess you can't have both.
Your thinking was the same as mine, WJP. I figured that the larger engine needed to breath better but the CVO mufflers didn't work out on my '06 95" build. I still have the mufflers, however, just in case emissions testing of bikes happens where I live.
I had V&H duals on my '06 Ultra before I went back to the stock headers. Most people report a little loss of low end torque but better higher RPM performance with duals. The problem with changing out two or three things at once (AC, mufflers, Duals, etc) is that you don't know which help and which hurt the performance in the RPM range you are looking for. On an Ultra I want low and mid-RPM performance in the form of higher torque assuming HP is not hurt in the process.
Texas Fat Boy
09-28-2012 11:52 AM
