Tour Pak Lid Organizer????? HELP
Old 10-18-2007, 11:14 AM
HarlyFan's Avatar
HarlyFan
HarlyFan is offline
Default Tour Pak Lid Organizer????? HELP
Has anyone used a "Tour Pak Lid Organizer" with the Spoiler Kit? In the part description in the HD book, it says that this will not work with the spoiler. Am I missing something obvious why will it not work?
Old 10-18-2007, 12:21 PM
hoosierhog88's Avatar
hoosierhog88
hoosierhog88 is offline
Default RE: Tour Pak Lid Organizer????? HELP
As a rule, HD is pretty much on target for their reasons when they say not to use something, if something else is installed.
It might fit, but it also might cause some "ripple effect" type of problems downstream. It may be minor, but there is probably some reason for it.
Old 10-18-2007, 12:42 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
IIRC, the lid organizer attaches to the lid with velcro. There may be interference with the velcro that attaches to the lid because of the bolts that attach the spoiler or interference with the organizer because of the wiring from the LED. Ask your parts guy at the HD store for the installation instructions for the kit and see if there is a problem or not.
Old 10-18-2007, 01:00 PM
HarlyFan's Avatar
HarlyFan
HarlyFan is offline
ORIGINAL: Harleypingman
Does anyone on the forum have the instructions for the tour pak organizer. How lame is that that I need instuctions for a velcro on piece.................
Old 10-18-2007, 01:01 PM
Merlin's Avatar
Merlin
Merlin is offline
ORIGINAL: HarlyFan
I have been using mine for over three years without any problems.
[IMG]local://upfiles/7589/84A510CE66344F6D96F855BEA1EEC591.jpg[/IMG]
Old 10-18-2007, 01:02 PM
HarlyFan's Avatar
HarlyFan
HarlyFan is offline
ORIGINAL: Merlinii
ORIGINAL: HarlyFan
Is there anykind of an interference with the spoiler kit?
Old 10-18-2007, 01:41 PM
Merlin's Avatar
Merlin
Merlin is offline
I'm not really sure that I really remember any issues. If there was it must have been very minor and very easily overcome.
Old 10-18-2007, 02:12 PM
rinja64's Avatar
rinja64
rinja64 is offline
I had the Harley lid organizer and was not real impressed with it. I picked one up from E-Bay for half the cost and I think it is a better quality product. The one from E-Bay has three large velcro strips which will allow you to remove it if you need to tighten the bolts of the spoiler.
Old 10-18-2007, 02:21 PM
Gviertell's Avatar
Gviertell
Gviertell is offline
I have the lid organizer. I do not have the spoiler. The organizer did not want to stay put on hot days so I put some holes in it and mounted it through the bolts for the rack. If you do not have the rack then I would look elswhere.
Old 10-18-2007, 02:47 PM
texan321's Avatar
texan321
texan321 is offline
ORIGINAL: Gviertell
Good solution - you also can get some 3M VHG tape 3/4" wide and place the tape in spots that will hit the lid - it takes 24 hours fro this tape to adhere but once it does - it ani't going no where....
Quick Reply: Tour Pak Lid Organizer????? HELP
