SG Air Suspension Pressure
10-17-2007, 11:36 AM
I haven't put any air in my rear shocks and have a fairly stiff bump when I go over RR tracks. The manual calls for 0-5 lbs for a solo rider. Should I add a little air and see if this helps or leave it with little or no pressure.
10-17-2007, 11:38 AM
RE: SG Air Suspension Pressure
Try the search feature at the bottom of the page.
Read, learn, make intelligent decisions
YRMV
10-17-2007, 11:45 AM
Yes, put some air in the shocks. That bump is the shock bottoming out.
10-17-2007, 11:50 AM
Check the manual but 5 lbs seems low. Mine is set at 10 lbs but I also weight 235lbs.
10-17-2007, 11:56 AM
If iremeber right there is a different table in the owners manual for the FLHX. The street glide uses a shorter shock then the rest of the FLH's and I think the air pressures are a little higher then the other bikes.
10-17-2007, 12:49 PM
Im about 185 and I run about 12lbs in mine. mine was set at 0 when I got it and was bottoming out all the time. 10-12 lbs is about perfect for me.
10-17-2007, 01:38 PM
I'm 240 and i run 18 with or without the wife 110.
10-17-2007, 01:44 PM
I'm 205, set mine to 8 lbs when solo.
10-17-2007, 02:14 PM
I'm 240 and run 10 lbs.
10-17-2007, 02:15 PM
Iadjust mine frequesntly and mostly ride 2-up. Me 235 her 130, we keep it around 25, any less and she really feels it.
