Cams and Heads on a 96"
RE: Cams and Heads on a 96"
TX - I have a cgreat ompression calculator spreadsheet I can e-mail you. PM or send me an e-mail with you actual e-mail address. No way to attach an excel file through the forum e-mail. I put in your numbers and it looks like 10.15:1 cold compression. The corrected compression (figuring in the cam specs) is the number you need to be concerned with. The calculator I have doesn't include the cams you are considering, but you could probably match it up to something on the sheet pretty close.
Let me know if you want it. Or anyone else is welcome to it also.
ORIGINAL: Biggzed
One thing you might want to consider is carefully checking the squish on your motor. I have read reports of pistons being quite a ways down the hole on '07's.
ORIGINAL: Biggzed
Big Boyz's web site has a easy to use calculator.
http://www.bigboyzcycles.com/showthread.php?t=118
I'm looking at doing the same thing ,with the HQ 500 or Woods TW6-6. I keep hearing mixed opinions on the cam noise with the TW6-6. Also I think it would need more compression, however on the Harley tech talk forum there are a couple of 96" TW6-6 builds that look very good.
Dave
Dave
My 95" with SE Heads at (as measured 72cc) and Flat Tops is 10-1CR with SE gaskets. I installed the Wood TW6 and put the D&D Fatcat back on and it's at the tuner as we speak. I don't know what I'll be getting, but I will say the bike pulls hard and feels very strong. In about one hour I'll be riding it after a Sabin tune.
06 Street Glide EFI
95" Big Bore
SE Flat Top Pistons
SE Twin Pro Performance Heads
Wood TW 6 Cams
D&D Fatcat 2-1
10-1 CR
The Wood cams are noisier than the old SE 203's, and about as noisy as my old Wood TW 5G cams. There is some valve train noise and ticking that I didn't have before. It's kind of relative actually. I asked my tuner today what he thought and he said he thought the cams were quiet. I thinnk after riding with the 203's ,which are so quiet, anything would sound a bit loud. I will say I LOVE how they pull, and as mentioned I will know in a couple of hours what I've got.
06 Street Glide EFI
95" Big Bore
SE Flat Top Pistons
Wood TW 6 Cams
D&D Fatcat 2-1
10-1 CR
Step #1 Head Volume (HV)
Convert Volume from Cubic Centimeters (cc) to Cubic Inches (ci).
________ cc / 16.39 = ________ (ci)
(cc from burette)
Step #2Cylinder Volume (CV)
CV=________ X ________ X ________ X (.7854)
(Bore) (Bore) (Stroke)
Step #3Compression Ratio (CR)
(CV + HV ) / HV = CR
____________div ____________ = _______________
(Cylinder Vol) (Head Vol) (CV+HV) Total
_____________ div ___________ =_______________
(CV + HV) Total Head Vol)(Compression Ratio)
Compression Ratio: _______________________
Compression Ratio calculated with a piston to head clearenceof
(Headgasket thickness):
(cc from burette)
I did the calc's wrong at first (forgot the stroke difference) with the '08 SE MCR heads & .030 cometic gasket I will be right at 10.5:1. If I had gone with the '06 SE Pro heads with the 72cc chamber, I would be closer to 11:1 (to high for what I wanted)
I just have to make up my mind on going with the Woods TW-7H cam or the Head-Quarters TC-575-HC.
When I replace my tires, I will change out the front pulley to the Andrews 30T and the rear to a '06 70T rear. That will give me a 3.15 rearend and then I just need to go find some stumps to pull!
