103 stage I & II
103 stage I & II
I have a 07 UC and thinking about the 103 kit for installation this winter. What is confusing to this non wrench: the difference between 103 Stage I Kit for EFI models and Stage II Kit for EFI models. Realize dollars, but what is the advantages and disadvantages between each.
RE: 103 stage I & II
sorry key board died. The cams should give you a bit more low end-mid range grunt. They are designed for 2 up touring I think. No real disadvantage, unless you want gear driven cams. But, since the 07's have the roller chains, I don't think you have the tensioner wear problem, so you shouldn't worry about it. Other wise, unless you want to try for max power from your motor, it's a good buy. Especially from one of the discount places like Zannotti's (spelling?)or Chicago HD.
ORIGINAL: gdbro4
The stage II uses the SE-255 cams. I have the Stage II on my 07 Ultra. With the PCIII, I am getting 82HP and 101 ft/lbs. torque. Love it except for the fuel mileage, 30-34mpg.
ORIGINAL: questor
OMG, 30-34mpg? Dang, didn't think it was that big of a hit on fuel mileage. Will it improve with more miles or is that it?
Tuning may help with that, but slightly higher compression Like 10. 1 or 10.5 to 1 and better cams should raise that up to 45 to 50 mph.
Head Quarters has 113 in builds that are getting 50 + with a carb!
ORIGINAL: gdbro4
After 10K miles, we're averaging 39mpg. That's 2-up, fully loaded. (you would NOT believe how much stuff she can cram into that tour pack)
My best tank was 43 mpg riding solo. Not great, but I like to ride a bit on the aggressive side?
If I really tried, I'll bet'cha I could squeeze 45 mpg without falling asleep from boredom.
[IMG]local://upfiles/36581/14D6BF1B7D5D4DB4AD71AE7469AEE1C0.jpg[/IMG]
ORIGINAL: gdbro4
I would also expect more along the lines of what BlackFlag has for results after "proper" tune.
If you are not comfortable with your tuner's ability, you may wanna consider a HQ ProTuner. It will work in conjunction with your existing PCIII and it will better manage your AFR & result in better performance and fuel economy. http://www.head-quarters-usa.com/protune.html
ORIGINAL: PhilM
[/quote]
Must be a copywrite thing. The documentation doesn't mention the PCIII.
