255s or other cam in a 103ci?
when swapping out cams in my 08 streetglide i was surprised to find that the stock cams lobes are pressed onto the shafts rather than being a part of the cam shaft itself. i asked at the harley dealership if they've had shifting occur and they said they have seen several which have shifted. screamin eagle cams are one piece rather than having the lobes pressed on. i'm using the se 259E cams and am quite impressed. this cam set comes in the kit which is used for the tri glide and includes the different valve springs and works well with the 10.75 to 1 pistons, but in your case with the 9.6 compression ratio they'd be way too much with the .579" lift. study in the parts and accessories catalog the 103" kits and what cams come with them. that would give you a great guideline for your application.
i have the same cams 259e and i love these cams plenty of pulling power great top end. cant say enough about these cams.
I got the Andrews 21 cams and they have good bottom end.
From what I've seen, the 255 cams are about the same, maybe more on top.
To do it over, I might go with the SE204 cams.
Look at the "dyno numbers for baggers" sticky for the 204 cams.
The 204's seem to have good bottom end and keep going past midrange.
Maybe check out the Andrews 48 cams too.
I would guess that the police 103 has the same cam as the Limited 103, and it is the standard 96 cam. My local shop has good results with the SE 255 cams and highly recommends them, says that power is right where you need it. They also say that if you are going to do cams, you should pull the heads off and have some head work done to get the full benefit. They need to breathe a little easier, or at least thats what I am told...
It's not wrong and you don't need to change valve springs or anything else. The SE255 is a true bolt-in cam set.
I have the 207 police model electraglide. It comes standard with the 103ci motor. compression is 9:6 and a recall allows for compression release heads to be installed. Most HD techs in this area are telling me that it does not come with 255 cams but probably something much milder. I am doing a stage one with A/C and either Rinehart or Vance and Hines slip ons. I will add true duals later. I am leaning toward installing the 2555 cam. I do most of my riding between 2500 and 4000 rpm. So I don't need cams that come on at 5000 rpm. I won't be drag racing, but I like a kick in the range that I described. Will the 255 make me happy or should I look at something else. I should point out that I know there are better aftermarket cams such as woods, andrews, headquarters etc. I want to stay with HD cams because of warranty issues. SO what should I look at in HD cams???? all insight is appreciated.
You can find these cams on Ebay for about $150 as CVO pulls. DIY and you can do the upgrade for <$300.
