Rinehart TD Install
Rinehart TD Install
Ineed help/suggestions. I installed Rinehart TrueDuals on my 07 ElctraGlide Classic.
It is very difficult if not downright impossible to tighten the bottom flange nut on the rear cylinder.
There is no room to get a closed end wrench on the nut. I surely have no earthly idea how you would begin to torque it to spec when you can't put a socket or wrench on it.
Anybody have any grand words of wisdom or guidance?
Thanks!!
Don
Thanks!!
Don
RE: Rinehart TD Install
When I installed my Bassani TDs, I found that I had to re-torque to specthe header pipe at the flange after adding each "part". For example for the right side, I torqued the header pipe to spec. After torquing the transmission cover bracket, I re-torqued the header pipe at the flange again. After securing the muffler to the saddle bag bracket, I re-torqued the header pipe at the flange again. I followed a similar sequence for the left side. About 2000 miles later, still no decel popping, even while coming down from 2000 to 400 ft elevation in VT at night (around 30 F) last week.
