Cold Weather & Fairing & Gloves
I would suspect the need is up to each individual person.
I would think it depends on how COLD, and how FAR. For example, 35 degrees for 10 miles might be tolerable, but 40 degrees for 30 miles would NOT be.
You can get a pair of heated glove liners for about 70 bux. Under a pair of HD midweight gloves that fit a little loose to begine with, I was fine on a RK (no fairing to block winds from the hands) into the low to mid 30s.
Best cold weather glove I've ever owned bar none. I've had them for 3 winters going on 4.
http://www.tourmaster.com/xcart/prod...=108&cat=9
My lower limit for riding is 24F (unless it gets colder during the day when I ride to work). Even behind the batwing, the most limiting factor is cold fingers. That's assuming that your're using a full face helmet. Air infiltration between the helmet and the jacket or at the ankles can be biting but isn't as bothersome as numb fingers. I've never used heated grips. Friends that use heat prefer heated gloves because the outer hand is warmed and they can be swapped to another ride a lot easier than grips. I use a wicking liner glove under Dry Tech outer gloves. They are Thinsulate lined gauntlet gloves by Joe Rocket with pull elastics at the gauntlet for a tight fit beween the glove and jacket. One thing I do is put my gloved hand on the front jug at a stop until I feel the heat coming through.
I just did a 300 mile ride today. 46 degrees was the warmest it got. I had my normal riding gear on. Leather Jacket, several layers underneath, long underwear and jeans, lined gloves and full-face helmet. The only thing I had to add was a scarf for the neck.
This was onmy Sporty with no windshield. It was cool but not cold.
Northern Illinois here. The weather is definately turning. UGH.
My suggestion is to either move someplace warm (10 more years for me)... or put her in the garage, open the checkbook, and start adding accessories, which is how I plan on spending my winter with my "girl". I'm looking forward to it! 6 more months 'till May!!!!!!!!!!
But I will take her out when the roads are clear just to keep her in shape. 30 minutes (above freezing) should be doable on an Ultra.
I just put the windshield back on the rk custom. I bought a bacalvia for my head, and it works great. I use hd winter gloves, and just started using latex gloves under them to fend off the wind. I don't own anything else that is really winter gear. I have a heavy leather jacket, and wear a set of over-alls over my other pants, LOL.(this is also my rain gear, LOL. I am cheap.)
Last year I set my bike up for winter. Lowered the coverage on the bike to save a dime. That will not be happening this year. If I wanted to take a ride, I would have had to call the insurance company, and let them know. Way to much trouble to save $100.
