Tour Pac Question!!
Tour Pac Question!!
I am looking at getting the Ultra Version Tour Pac for Road Glide (as soon as I get it!) My question is, with the lights how do you get power up to the lights on the pac? Is there a plug somewhere that you just plug and unplug it to make it removable? And also when it is not on there where does the plug hide at?
Thanks for any info on this!
RE: Tour Pac Question!!
If you don't have the plug in your wiring harness you can get the pins and plug that mates to the tour pac and build it then splice the wiring into the rear tail light harness under the seat behind battery over the rear fender as I've done. The Road King wiring is not equipted for the tour pac to be pluged into it stock.
ORIGINAL: 08roady
[IMG]local://upfiles/33788/A7353BE1342845B2924BDC905C823F4B.jpg[/IMG]
You will find the plug tied to the air lines for the rear shocks on the left side.
Here is a link to how to install the brake lights in the tour pac if they aren't on it already. You will see the plug in one of the pictures.
https://www.hdforums.com/m_1447481/tm.htm
08Roady: Congrats on the ride; it's going to be a beauty.
Are you also ordering the rear speaker kit andCB kit? I ask because the Ultra boxescome pre-drilled for mounting the speaker pods and the CB antenna mount so you will have easily visible holes in that beautiful $1000 box without the pods or CB antenna mount installed.
Some guys have filled the speaker pod holes with plastic plugs and color-matched them with HD touch-up paint that can be ordered from the dealer. Others have purchased after-market rear speaker pods from Hogtunes or Eglide goodies.
Pingman,
Thank you for that info, I did not know that those came with the holes for the speakers. Know I am back to the drawing board, I don't think I want to do the speakers in back, sounds like it would be too much of a pain in the **** too me!! I guess I am going to have to go with the King Tour Pac. So if I go with this one, I can just buy the light kit? Does anybody know the part # for it?
